Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 01-12-2023, 06:38 PM
banjo71 banjo71 is offline
Default What does "Normal" cache size mean in playback
If I have 8 gigaabyte of RAM on my laptop, and I go to disk cache size in PT 12 in Windows 10... default sets it to "normal", but 256, 512, 1G, 2B...etc is optional. I'm going to test it at 3 gigabyte since I have a hard drive that runs at 5400rpm. I'd just like to know what "normal" is.
Pro Tools 12.6.1 for Windows 10
ASUS Core i7 3770
Yamaha Steinberg UR 44
Golden Age Project Pre-73 JR
Warm Audio WA12 MKII Preamp
Glyph 1TB GPT50 external drive - Firewire
LaCie 1TB external drive - USB
JBL LSR305 monitors
AT 2020 & 2021
Equation F.20 condenser mic
Old 01-12-2023, 06:53 PM
Default Re: What does "Normal" cache size mean in playback
8GB of memory is bare minimum for 64-bit Pro Tools. Maybe for Pro Tools 12 it was the actual minimum spec amount. I'd say more like 16GB minimum is a healthier space. And if you plan to use lots of VIs... who knows. Taking 3GB out of your precious 8 GB is probably not a good idea.
Normal == cache features are partially/largely disabled, does not preload, etc. Lots of discussion on DUC in the past.
Disk cache does not help VI sample load performance, can increase session start up time etc.
The best way to fix a 5400 rpm drive is buy a fast SSD. They are not expensive.
Old 01-12-2023, 08:37 PM
smurfyou smurfyou is offline
Normal means cache size is automatic and scales for the session size and available memory. It is not disabled.
~Will
Missing all the "DAE Playback Buffer Size" settings in Pro Tools 11 & 10? music.mak macOS 1 09-21-2014 10:29 AM
Dual buffers in PT11 - what is the buffer size for the "playback" buffer? yeloop Pro Tools 11 3 07-21-2013 07:41 PM
playback buffer size and "static" with rhythm guitar tracks chrisad2 Pro Tools M-Powered (Win) 1 02-14-2012 08:49 AM
MBox 2 WaveForm not recording right/"normal" on Input 1 EDF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-16-2011 09:08 AM
"Normal" compression for vocals on pop or rock song? Mike Teslow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 37 02-12-2009 09:17 AM
