Old 10-03-2022, 03:39 AM
devs1980 devs1980 is offline
Default 2022.9 and Waves broken
Anybody else having problems with Waves plugins not working properly? Some of my old Waves plugins keep crashing it, not a problem I'd encountered with the previous version
Old 10-03-2022, 05:38 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 2022.9 and Waves broken
I had zero issues with Waves when they worked on TDM cards, but ever since they abandoned iLok everyone I know of is reporting all kinds of weird stuff regarding Waves Native. I myself abandoned Waves, because I made myself swear next time I re-wup is the day they support HDX. That day may never come.
Janne
Old 10-03-2022, 06:32 AM
its2loud its2loud is offline
And here we go again
No issues here with Waves and 2022.9 but you need to provide more info for the forum. What exactly do you mean by “old”?
Waves version
System
OS,
Etc,etc,etc
Old 10-03-2022, 09:24 AM
MEIStudio MEIStudio is offline
Same issue here. Updated to 2022.9 and something is wrong across all versions of the Waves plugs. Granted mine are long in the tooth. I'm currently running v9, 10, and 11 plugins.
Strangely, the v11 plugins crash protools instantly, whereas the v9 and v10 plugins just have UI issues with higher resolution screens. (they appear small in the corner of the plugin window on higher resolutions and the controls are where they should be on the full window if that makes sense... so a knob thats supposed to be in the middle is still in the middle of the screen, but the GUI is a tiny little thing in the corner). If i move the plugin window to a monitor with a lower resolution, its fine.
Old 10-03-2022, 10:48 AM
npapaleo npapaleo is offline
Yup, having the same waves issue on my M1Pro MacBook Pro on Monterey 12.6/Waves 14/PT 2022.9 and my Intel MacPro 7,1/Waves14/PT 2022.9 systems. Plug-ins won't load and just cause PT to freeze. Luckily I can easily work around any waves plugs, annoying none the less.
Old 10-03-2022, 10:58 AM
No issues here with Waves. All updated to V14
Mac Studio Max 64GB 2TB
macOS 12.5.1
Pro Tools Ultimate 2022.9
HDX + Sonnet Echo III-D
MTRX Studio
Scott Gatteño
Old 10-03-2022, 11:11 AM
daeron80 daeron80 is offline
No issues here with v14 of CLA comps, the Renaissance suite, and WLM.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-03-2022, 12:02 PM
off the wall's Avatar
off the wall off the wall is offline
No issues with Waves V14 plugs. PT 2022.9. macOS 11.7. I am a heavy user of Waves Plugsins.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 10-03-2022, 12:37 PM
According to the Waves and Avid Compatibility charts, you would need at least Waves V12 to be on a fully supported PT 2022.9 system. That would be running Catalina 10.15.7. Any higher macOS and you need Waves 13 or 14.
Old 10-03-2022, 03:57 PM
Yeah figured as much, just have to decide if its worth pouring any money into. I use some of the GTR stuff every now and then from my bundle, but i also have like 4 other suites (guitar rig, helix, eleven, softube and probably others). Guess its time to make the decision to just dump waves altogether and move on from that circus or pony up to continue to use their stuff... Funny how none of the other plugins i use run into these issues.
AutoTune 8 (8.1.8 and 8.0.4) broken in 2022.9 anearforgear Pro Tools 20 01-31-2024 12:06 PM
Custom Shuttle Lock Speed broken in 2022.5 [PT-290238] ArchStanton Pro Tools 31 10-26-2022 10:38 AM
Duy plugins gui broken in 2022.9 ejsongs Pro Tools 1 10-03-2022 12:39 AM
Looping regions (Audio and MIDI) broken in 2022.6? XJENSEN Pro Tools 3 07-12-2022 10:26 AM
Is the MIDI zoom on the edit window broken in 2022.05 Windows? snowplaysmusic Pro Tools 1 06-17-2022 06:44 PM
