Old 09-28-2022, 11:16 AM
ejsongs ejsongs is offline
Default anyone try 2022.9 with Mojave??
This question, and are the midi bugs gone?
Thanks,
Ej
Old 09-28-2022, 12:57 PM
blinches blinches is offline
Default Re: anyone try 2022.9 with Mojave??
Bump
Old 09-28-2022, 01:06 PM
Sparky1 Sparky1 is offline
Just opened a session with 2022.9 on Mojave…. So far so good…
Have not tried midi yet…
Sparky
Old 09-29-2022, 09:58 AM
michael c michael c is offline
Anyone else running Mojave with 2022.9? Any issues?
Thanks.
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.6.8
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.6
HD Native Thunderbolt
Old 09-29-2022, 10:00 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Smooth here.
Midi seems fine...(Quantize issue)
Old 09-29-2022, 10:20 AM
massivekerry's Avatar
massivekerry massivekerry is offline
Fiddling around with it a bit. Haven't noticed any problems.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 09-29-2022, 10:23 AM
abomeerza abomeerza is offline
everything very fine here 10.14.6
Pro tools Ultimate
AVID HDX , Pro tools Ultimate 2021.6 , Avid C24 , Lynx Aurora 16 (n) , mac pro 12 core , Mac OS Mojave
Old 10-01-2022, 07:16 PM
Studio Crash Studio Crash is offline
I'm running a 5,1 cheese grater Mac Pro (12-core 3.33GHz, 96GB RAM) with Mojave and the Pro Tools Ultimate 2022.9 update seems to be fine. I have Melodyne Studio and it's working both as a traditional plugin as well as the new integrated ARA version. It stops from time to time with a pinwheel to update / synch, but not too bad. I just wish I could open it in it's own window.
Mac Pro 2010 12-core 32GB / High Sierra / Avid HDX / 192digital / 96io (2x) / Pro Tools Ultimate 2019.5 / D-Command 40 fader / www.studiocrash.com
Old 10-01-2022, 08:40 PM
If you load it as a separate insert - you should be able to open Melodyne as a separate window...
Sparky
Old 10-02-2022, 08:21 AM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
I did have some midi on and an existing session that played a VI sustain wrong and had to adjust it manually to get it to play correctly. But, other than that it seems to be working smoothly so far.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
OSX 10.14 Mojave milescoolin71 Pro Tools 12 4 06-06-2022 09:19 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
Mojave on PT 2022? SDDP Pro Tools 18 12-30-2021 03:07 PM
Mojave 10.14.6 ? Blues Bird Pro Tools 2019 15 09-01-2019 03:36 PM
