Old 07-14-2021, 05:26 AM
mnstudio mnstudio is offline
Default Configuration window on 2 monitors issue
I saved a window configuration where Edit window is on the monitor 1 and Mix on the monitor 2.
For a while, reloading the configuration preset, all was fine.
Now, every time I reload it, the Mix window is loaded on the background of the Edit window in the same monitor 1. Why? What I miss?
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 07-20-2021, 05:52 AM
Default Re: Configuration window on 2 monitors issue
I found the trick.
The second window (the one on the second monitor) has to be a little smaller than the maximum. In this way the system and PT re-open the configuration in the right way
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 07-27-2021, 02:48 PM
cwsand's Avatar
cwsand cwsand is offline
Actually, if you have a smaller sized window and then Option+Click the green + sign at the top left of the window, it should maximize the window to the proper size and retain that size when you close and reopen the session. Works for me at least.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-28-2021, 12:28 AM
Absolutely it works! Thank you so much cwsand
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Unreliable Window Configuration Feature on Two Computer Monitors Kam Lion Pro Tools 2020 1 11-15-2020 09:32 AM
Window Configuration Bug - Track/Groups window keeps reappearing! cantgetnosleep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-25-2010 11:34 AM
Window Configuration tsr2 Pro Tools TDM Systems (Mac) 2 09-22-2008 03:47 AM
Window Configuration Bug tj_davies Pro Tools TDM Systems (Mac) 3 11-01-2007 01:32 AM
Windows configuration probs when across 2 monitors crizdee Pro Tools TDM Systems (Mac) 0 12-11-2006 07:30 AM
