Old 12-05-2020, 09:04 AM
jphaudio jphaudio is offline
Default Pre-Fader vs Post-Fader Metering
I am over thinking this, but I am hearing different viewpoints on pre and post metering for mixing and recording. I use post fader metering for mixing and just check levels before recording with pre-fader metering. Is this correct? I think I have been fine but am now second guessing myself. If anyone has a moment to add what is the norm and/or how they use pre-fader if at all?
Thank you!
Old 12-05-2020, 10:30 AM
Default Re: Pre-Fader vs Post-Fader Metering
To each their own, but here's my 2 cents:
I almost NEVER use post-fade metering. Why? Because I want to know what's going on IN the track, and the volume(fader) level is not part of that which I want/need. Consider; pulling the fader down with post-fade metering might make the meter show a nice happy green level, while there is clipping going on before the fader. Pre-fade meters tell me what's happening before the fader(so the fader doesn't give a false impression of anything).
The ONLY time I use post-fade metering is when I need to balance several(as in more than 3 or 4) tracks with similar audio, such as 14 tracks of violins, or 8 tracks of BGV's. And, as soon as those tracks are balanced out, my metering goes right back to pre-fade. The rest of mixing/balancing needs to be done with your ears and not your eyes
Old 12-05-2020, 10:35 AM
Thank you, just over thinking on my end. Thank you!
Is it possible to set metering to both pre-fader and post-insert when tracking? jsbach Pro Tools 2018 1 05-03-2018 05:17 AM
Pre and post fader metering on each track independently. Emcha_audio General Discussion 6 11-17-2012 12:34 PM
Pre-Fader Metering vs Post-Fader Metering teacherman Pro Tools TDM Systems (Mac) 3 01-29-2008 07:33 PM
shortcut for pre/post-fader METERING switch. Stefan Luan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-04-2006 04:17 AM
Pre or Post fader Metering? Forrest77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-20-2003 12:35 AM
