Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 02-24-2016, 05:08 AM
martthie_08 martthie_08 is offline
Default HD native thunderbolt with thunderbolt card on desktop PC?
as the title says, is there any support for PCIe thunderbolt cards for HD Native? I am stuck with the thunderbolt version and want to use it on a win8 PC without onboard thunderbolt ports.
This is what I've found so far:
http://www.pro-tools-expert.com/home...omni-interface
https://www.scan.co.uk/products/asus...displayport-in
thanks!!
Old 02-24-2016, 08:27 PM
Default Re: HD native thunderbolt with thunderbolt card on desktop PC?
thanks!!
So?? Are you simply asking if HDN PCIe works in Windows?? Yes, lots of us use it.
Or do you mean actual TB PCIe cards for your PC? If that's the question, it depends if your motherboard supports it. It won't work with any motherboard and has to have specific connectors on the board along with the PCIe slots. What motherboard does your system have?
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 02-28-2016, 06:30 AM
thanks for your reply!
yes!
ok, what connectors would that be?
I will check tomorrow.. I believe some ASUS board
Old 02-28-2016, 06:45 AM
Similar questions keep coming up on DUC... you can search for previous posts.
Look up your motherboard on ASUS' web site, it may be one of a few that supports an ASUS Thunderbolt expansion board. What connector does it have? Well PCIe and more but it is ASUS proprietary so ya gotta get it from them *if* your motherboard supports that option at all. Apple insisting that Thunderbolt include graphics pretty much ensured there is no easy retrofit path for Thunderbolt in PCs. Thank the geniuses in their walled garden, and Intel for listening to them.
But then at best you get Thunderbolt on a PC, which is not officially supported by Avid HD Native. Which may or may not work, with problems or not. Seems like a good old waste of time when you could just go buy a used PCIe HD Native card and sell your HD Native Thunderbolt card if needed.
Old 02-28-2016, 09:10 AM
yes!
There is a specific port of the motherboard for TB beside the PCIe slot that is the default for it and attaches the card through an adapter to the board. Again, look up the board. Most mid-high end Asus boards from the z87 chipset forward support it. HDN has been surprisingly compatible on Windows TB systems.
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 03-01-2016, 01:48 AM
ok the main board is a Gigabyte Z97X-UD3H-BK, it seems there are no explicit firewire options available for this main board (at least from the vendor).
Old 03-01-2016, 07:29 AM
And it has no Thunderbolt support either No upgrade path here.
You could have purchased, received, installed and been using working using a used PCIe card by now.
Old 03-01-2016, 07:47 AM
Thanks everyone!
Unfortunately this is not my system (have HDX myself) so I can't go out and sell the Thunderbolt box and get PCIe hardware...
Old 03-01-2016, 09:52 AM
Thanks everyone!
Only other resolve is the upgrade the motherboard to something like a z97-UD7-TH
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 10-12-2016, 10:26 PM
adogg4629 adogg4629 is offline
So I was able to get an HD Native to work on an MSI GT73VR using a USBC Thunderbolt three to thunderbolt adapter. Everything went fine, but I noticed that on my Omni, the volume and mute doesn't work. I get a nice level out of it, I just can't manipulate it.
AD
Trade hd native PCIe card for hd native thunderbolt card and cash? Brandonx1 Buy & Sell 8 03-22-2015 01:45 AM
HD native card in Magma Xpressbox1 w Omni on MacBook Pro i7 - pre-thunderbolt dugongmusic Pro Tools HDX & HD Native Systems (Mac) 14 08-07-2014 07:00 PM
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
FS: HD Native PCIe card and Thunderbolt enclosure vocomotion Buy & Sell 0 08-24-2013 02:19 PM
Native Card vs Thunderbolt external brickroadstudio Pro Tools HDX & HD Native Systems (Mac) 1 09-28-2012 01:17 AM
