Sync HD & Black burst
Can Sync HD handle 96 khz black burst signal? cuz I'm going to record a concert under 24bit/ 96khz, and want my audio and video synced to frame accurate. thanks
Re: Sync HD & Black burst
You can do this. "Black burst" is a standard video reference signal that defines the VIDEO frame rate. It is the same video reference signal no matter what sample rate you operate Pro Tools at. While SyncHD is locked to a black burst signal it will ensure that your PT audio hardware is time-locked to the video reference.
system specs in profile |
Thanks for the info , Postman, So, it doesn't matter what sample rate black burst is , right? cuz, I don't have sync hd to test it before recording date, but I thought when I choose Video Ref as the master clock , the session must follow it ....??!!
Black burst operates at a frame rate. The frame rate of the black burst will be determined by the frame rate the videographer uses for the recording. Possible frame rates are:
Why NEAR sample accuracy? Some of the black burst frame rates listed above are not evenly divisible by a given sample rate.
Here's a quick review of the basics For us, sample rate is the speed at which your audio hardware converts between analog and digital worlds. Video picture uses "frame rate" (standard ones are listed above), which is the number of still images per second a camera records a real time image. The only relationship these two rates have to each other is they both use seconds as a timebase. Samples per second of audio. Frames per second of video. Your session determines the sample rate. In the session setup window you can select any of the standard frame rates, which does NOT change the sample rate. Video determines the frame rate. Audio does not care what the frame rate selection is because audio sample rate is not affected. In your session settings window you can tell SyncIO which type of video reference signal will be applied to it. SyncIO will be able to lock onto that signal and determine how long exactly a second is (relative to the video). It then operates its sample rate clock to output the exact sample rate clock to fit the video signal. Again, the number of samples per second, the sample rate, is determined by your session. The video frame rate is determined by the video in use and the selections you make in the session setup window. Making them actually operate with a near-perfect relationship is ensured by SyncIO (with selections you make). I noted earlier that there are separate settings for session frame rate and video reference frame rate. Often these are set the same but they do not have to be. For example, it is possible to view and work with 23.976 frames per second video in your session while using a 29.97 frames per second video reference. In such a case, the session's frame rate would be set at 23.976 while SyncIO's video reference setting would be 29.97 or NTSC. This had been a common workflow during the transition from SD to HD video. One other interesting detail is that the standard audio sample rate for ALL broadcast and theatrical presentation has been 48kHz, no matter with the frame rate is. There is nothing wrong with working at 96kHz. Perhaps you will be able to keep 96 all the way through a Bluray release, but for many uses it will need to be converted to 48Khz. I hope this is helpful.
system specs in profile Last edited by Postman; 02-01-2016 at 05:24 AM. |
It wasn't always that way. (Shudder.) Took a little while for chips to come along that could do all the math. And we used to make it really hard on ourselves by using 30 frame resolve for music production (PCM1630 anyone?) and 29.97 for video. Caused quite a few tantrums back in the days of capstans and pinch rollers.
Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9 www.remotewest.com @RemoteWest |
using sync i/o as video black and burst gen? | James Drake | Pro Tools TDM Systems (Mac) | 1 | 08-05-2010 07:48 AM |
Sync I/O & 30 frame black burst (Video Ref) | ByfarProd | Pro Tools TDM Systems (Mac) | 0 | 01-04-2005 11:56 AM |
Black burst and other stories! | poppy | General Discussion | 3 | 02-12-2003 04:40 PM |
Black Burst to ABVB via USD? | Samhein | Post - Surround - Video | 2 | 01-21-2000 06:58 PM |
64XTC, Hi-Fi VHS, no black burst..... | Farmer Dave | Pro Tools TDM Systems (Mac) | 3 | 10-12-1999 10:33 AM |
