Old 07-01-2015, 10:37 AM
volkgti90 volkgti90 is offline
Default Any idea why Spacebar / Playback randomly stops working??
Ever since i upgraded to PT11 i have had this problem no matter what version I'm running (11.2.1, 11.2.2 etc). I use PT everyday for work and work with short video clips (average 2 to 6 seconds long) as I build sound design for online video games. The problem I'm having is every 10 minutes or sooner, the spacebar just stops responding when i try to playback mid session. The play button and stop button will just flash and nothing will happen. There are only two work arounds i have found, with one only working 50% of the time. First, if i hit return and go back to the start of the session, the spacebar will 50% of the time start working again. The other solution is i have to close Pro Tools and reopen to get the function back. This is really frustrating and definitely interrupts my workflow. I have tried multiple different video formats to try and cure the problem and nothing seems to work.. Any info would be more then appreciated. Thanks
Computers used:
Macbook Pro 13'' i5 2.9ghz 8gb ram - PT11 11.2.1
Macbook Pro 15" i7 2.6ghz 16gb ram - PT11 11.2.1
Playback Stops Working After Sitting Idle peytontodd Windows 4 02-27-2015 12:46 PM
9.0.3. Sound just stops working during playback? DJ Hellfire Windows 7 07-23-2011 12:58 AM
Delay Compensation Randomly Stops Working edit machine Pro Tools TDM Systems (Mac) 6 11-02-2010 06:45 AM
003 fader randomly stops working. GloryIsSilent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-16-2010 12:33 PM
002 randomly stops working!! reyalp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-24-2006 06:12 PM
