Old 03-18-2015, 09:17 PM
austinmusic austinmusic is offline
Default How to access Inserts F-J [SOLVED]
How do you access Inserts F-J of an instrument track so you can add more effects?
Old 03-18-2015, 09:21 PM
Default Re: How to access Inserts F-J
Never mind, I figured it out. All I had to do is right click over "Inserts A-E" and select "All". Sorry about the dumb question.
Old 06-04-2016, 03:37 PM
dg27's Avatar
dg27 dg27 is offline
Default Re: How to access Inserts F-J [SOLVED]
Maybe you thought it was a "dumb question," but it helped me! Thanks for the followup explanation!
Old 03-26-2023, 03:18 PM
djjamesc djjamesc is offline
Thank you quick google search your self discovered answer helped me.
(SOLVED) BUG:Can't access all busses (not visible on screen) beggehorn Pro Tools TDM Systems (Win) 13 03-07-2022 11:34 AM
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
PDC Question #1 - Aux Bus Inserts - PARTIALLY SOLVED. original_min 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-04-2008 05:59 PM
Access Violation error issue solved daeron80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-11-2006 03:52 PM
access violation using stereo inserts 5-6 M Smith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-26-2002 08:14 AM
