Old 05-18-2014, 11:30 AM
WinstonDeath WinstonDeath is offline
Default Nothing but "Undo Change Control Value" in undo queue
In Pro Tools HD 11.1.2 my undo queue contains nothing but "Undo Change Control Value" 90% of the time. I'm not making automation adjustments, only edits, and it happens regardless of the automation mode the tracks are in, or what is write-enabled in the Automation Window. Sorta removes the functionality of undos entirely.
Anyone else? Any ideas/solutions?
Thanks.
Old 05-19-2014, 01:53 AM
Stig Eliassen's Avatar
Default Re: Nothing but "Undo Change Control Value" in undo queue
Setup (menu) > Preferences > Mixing tab, bottom left (Include control changes in undo queue).
Old 05-31-2014, 05:40 PM
It's not that. Like I said, I'm not making control changes. This happens simply by playing the transport. As soon as you press play, it starts to log control changes regardless of if you move a fader, knob, or switch. If you're in preview you can see the write status of tracks randomly light up green, and if you're in latch they light up red.
Old 05-31-2014, 05:42 PM
I'll add that the faders don't actually latch on, but the undo queue logs changes even though there aren't any.
Old 06-01-2014, 04:28 AM
Do you have any kind of hardware controller connected?
Have you tried to Delete the Pro Tools Preferences?
I'll try to repro this here as soon as I can.
Old 06-01-2014, 08:38 AM
Thanks.
Something's definitely wrong; maybe try turning off all midi inputs.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 06-02-2014, 11:51 AM
I have used the Neyrink V-Control App, but I wasn't running it at the time I posted this, and if memory serves it was happening before I even installed that. I have no actual physical control surface hooked up.
Old 06-02-2014, 05:34 PM
again, disable all midi devices (Setup -> midi -> input devices) and see how it behaves.
Old 06-11-2014, 10:08 AM
So disabling all controllers seemed to fix this for a minute, but I think it was coincidence. I have now had the same issue on a system running HDX and system running HD with no hardware, with either the Neyrink app, an Avid Artist Series EuCon controller, or no controller at all.
Thanks for the responses, guys.
Old 04-24-2015, 03:46 PM
adogg4629 adogg4629 is offline
I have a fresh install of PTHD 11.3, with no controller (ever). This is an annoying bug.
Undo Issue - "Change Control Value: Automation Warning" admix Post - Surround - Video 11 09-20-2013 08:08 PM
UNDO: Why do i have multiple "Change Control value" before undoing what i need? EDurney macOS 5 01-10-2012 08:55 PM
"undo" function and history on 1 track? dendee Pro Tools TDM Systems (Mac) 1 11-04-2008 09:55 AM
Question about the Undo Queue garagemusic Pro Tools TDM Systems (Mac) 6 02-13-2005 11:26 AM
What Commands Clear The Undo Queue? nozza1 Pro Tools TDM Systems (Mac) 5 06-15-2001 02:46 PM
