Old 02-25-2011, 09:27 AM
entfred entfred is offline
Default newbie problem getting sans amp effect turned on
I have a Windows 7 PC with one of those $50 Guitar Track M-Audio boxes running the scaled down version of Pro Tools. I updated all the drivers for
M-Audio and Pro Tools. Everything seems to be installed fine.
I bring up Pro Tools and opened a few of the sample projects. When I had
the "rock" project open, I tried recording over one of the guitar tracks that
features the use of the Sans Amp plug-in that comes bundled with this
version of Pro Tools. I only get the clean output of the M-Audio box without
any distortion effects, when I record over that track.
How do I turn on the Sans Amp (or any other plug-in effect) for the track
that I select? Is there something I click on?
I found Pro Tools easy to record with, but am banging my
head trying to figure out how to turn on Sans Amp while I am recording.
I can access the Sans Amp window with all the Sans Amp controls, but
I can't actually get the Sans Amp sound that I adjust to come out of
the m-audio box into the headphones I am using. And of course, the
recording comes out with the guitar clean instead of with the Sans Amp
distortion/overdrive.
What settings would you use in the control panel for the M-Audio box as
far as sound input and output? I tried different combinations but was
just able to get the clean guitar sound recorded without the Sans Amp
distortion effects (i.e. that the example "rock" project had on a few
guitar tracks).
Thanks for any advice on this!
Old 02-25-2011, 09:48 PM
Default Re: newbie problem getting sans amp effect turned on
SansAmp is a plugin that you would insert on the track you want to process.
Stutter effect popping problem Danny Winn Tips & Tricks 6 09-08-2013 11:40 AM
ADC problem, crashes PT9 when turned on gsguitarest macOS 3 02-08-2011 11:18 PM
Newbie: Selector Turned Scrubber Permanently?! Rubyflux Pro Tools M-Powered (Win) 4 11-17-2006 07:37 PM
Finally a new vocal effect to put the Cher effect to bed!!! ***BboY *** 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-22-2002 09:11 PM
sans amp plug-in problem rich baker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-04-2000 09:32 PM
