Old 02-19-2011, 06:53 PM
Raamond Raamond is offline
Default Playback Dist...
I'm working with M-Powered ProTools 8.0.4cs on Windows 7-32 bit. I'm tried everything possible including searching for answers googling. Please help...
Old 02-20-2011, 05:13 AM
lincol1 lincol1 is offline
Default Re: Playback Dist...
Here's one thing you might try...describe your problem...
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 02-22-2011, 03:58 AM
Tetsuo Tetsuo is offline
lincol1
here's one thing you might try...describe your problem...
+1
Old 02-23-2011, 11:43 AM
ok. I'm working with Pro-Tools M-Powered 8.0.4cs on Windows 7 32-bit. And after several testings and research, I can't seem to figure out what cause distorotion during playback. I've tried several different settings with the M-Audio control panel and nothing seems to work. I've thinking the signal is coming in too hot, so I can I control that with the control panel or I'm recording a double feed. Any suggestions would be nice, Thanks
I have a 24/96 sound card from M-Audio and I'm using a Behringer Eurorack UB2442FX-Pro with the rca cable going in to the tape in and tape out on the mixer.
Old 02-23-2011, 04:48 PM
Distortion during playback could really be anything. Such as the obvious, you are playing back audio that is distorted. Or you could have improper gain staging. Plugins could be clipping not to mention the tracks themselves could be over.
Either playback some audio you know is not distorted such as a loop or trace the signal from start to finish making sure you are not clipping at any of the many points along the way.
Lincoln Mitchell
www.studiofifty.net
VCC + SSL strip = 2 times desk dist? Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 8 10-09-2012 10:31 PM
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou JLue Pro Tools 9 1 08-04-2011 08:59 AM
Fuzzy Static with ProTools playback and window media files playback 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2011 05:41 PM
CORRECTION: Adat Device doesnt playback audio during Recording or Playback DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-21-2010 11:16 PM
Lines 6 Pod/Pod Pro & tape delay/dist/chorus modelers. Is our Amp Farm old hat now? Jules Pro Tools TDM Systems (Mac) 5 09-17-2000 08:00 AM
