Digidesign Audio Drivers Install Problem
I have been trying to re-install Digidesign Audio drivers on my PC but the program hangs and will not complete install - I’ve run Pro Tools LE 7.4 and Cubase 3 with Digidesign’s 003 for some time without any problems but I recently installed Cubase 5 and it was not seeing the ASIO driver. As I no longer need Pro Tools on this partition I thought I’d try a re-install – just using the ASIO drivers.
Running regedit I removed all related files but found the following files/folders could not be deleted: Digidesign folder: HKEY_LOCAL_MACHINE\ Software DeviceDesc, Mfg, 1394\Digidesign&_003: HKEY_LOCAL_MACHINE\System\Control001 Erum\1394\ AA007EA000 Ethernet Support: Root\ LEGACY_DIGINET\0000 MME Refresh Service – Enum\Root I’m guessing some of these files are required to run the 003. I have run Pro Tools 7 & 8 Uninstallers downloaded from website; Ver. 7 finished ok… but ver. 8 hung - I had tried installing Pro Tools 8 - installed on my DAW partition. My original re- install was run from original Pro Tools CD but I have just tried Digidesign Audio_Drivers_7, downloaded from Digi Website, with no success. System Spec: Windows XP Home SP3, Intel Core2 Quad Q6600@ 2.40 GHz, 3.24 GB Ram Dual Boot setup on system drive I would welcome any thoughts in sorting out my problem. |
problem installing digidesign audio drivers (beta) for windows 7 64-bit | Applebase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-23-2011 12:56 AM |
problem with PT 8 install - digidesign audio drivers returned an error 2147213312 | music project | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 38 | 05-30-2010 11:38 PM |
Do i need to install the Digidesign Audio drivers? | Dan-Jay | General Discussion | 0 | 04-20-2010 11:54 PM |
Must remove digidesign audio drivers to install LE 7.3 | flinglebunt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-05-2007 01:12 AM |
DigiDesign 002 Drivers Won't Install!! Freezes! | ArachPres | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-07-2004 05:28 AM |
