Old 05-22-2010, 09:43 AM
Wallimann Wallimann is offline
Default Error installing ProTools 8...
Hi everyone!
I just got a brand new Eleven Rack and am trying to install it on my IMac.
I am using Snow Leopard 10.6.3..
I keep getting the following message to the end of the install:
System extension cannot be used
The system extension "/System/Library/Extensions/DigidesignElevenRack.kext" was installed improperly and cannot be used. Please try reinstalling it, or contact the product's vendor for an update.
The install seems to go through, but I just hate to have an install with an error message in it. I'd like a clean instal, you know...
I read somewhere that I should try installing the latest Pace driver from http://paceap.com/, but it did not fix the problem...
Is my DVD disc corrupted?
Help!
Old 05-22-2010, 11:23 AM
desperate installer desperate installer is offline
Default Re: Error installing ProTools 8...
I am having a similar problem. I am trying to install Pro Tools 8 (came with Mbox 2) on my Mac (specifications below). At the end of the installation process, I always get this massage:
The installation failed. The installer can't write the receipt for "Plug-In updates"
I have learned already that you need to download an update to Pro Tools 8.0.3 if you use Snow Leopard:
http://avid.custkb.com/avid/app/self...p?DocId=362799
But, even following all this recommendation still results in the same failure message.
I spent 600 EUR on equipment two days ago and would like to get started. Being held up with the installation really sucks...
Please help!!!
Many thanks in advance
______________________
Snow Leopard 10.6.3
Model Name: MacBook
Model Identifier: MacBook5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 1.07 GHz
Old 05-22-2010, 05:31 PM
higginsdj higginsdj is offline
I've not had any problems with installation on my OSX 10.6.3 iMacs (2 of them) - BUT - I am using the PT install disc that came with 8.0.3 on it. I assume that the updates for Leopard are 8.0.3 as opposed to an update to 8.0.3?
Cheers
David
PS - you have run a repair on your disc permissions haven't you?
Old 05-23-2010, 12:18 PM
Unfortunately my instal disk is version 8.0...
I would upgrade to 8.03 if only I could install version 8.0 without any errors...
I did do a disk repair, but still getting errors...
This is frustrating!
I just got a brand new Eleven Rack and can't use PT yet... :-/
Old 05-24-2010, 08:48 AM
Ok, I fixed the problem.
I uninstalled PT8 completely, then ran the upgrade with my original PT DVD in the drive.
No errors!
Thanks everyone.
Urgent:Error Messages when Installing Protools 8 LE JJ2739 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-20-2010 12:23 AM
I/O error (-36) after installing 7.2 jakemoss Pro Tools TDM Systems (Mac) 6 08-09-2006 07:07 AM
error when installing protools theswarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-14-2005 04:31 PM
Neoaccess error after installing protools 6 niki111 Pro Tools TDM Systems (Mac) 5 02-16-2003 08:53 PM
installing protools in G4 400 & OMS ERROR MESSAGE Marc Cooreman Pro Tools TDM Systems (Mac) 3 11-01-2000 04:43 AM
