Old 03-18-2010, 07:27 PM
GloryIsSilent GloryIsSilent is offline
Default 003 fader randomly stops working.
It appears that if I enter flip mode since 8.03, my 5th fader will stop responding or sending signals. It will not move in utility tests either.
This will persist until the unit is powered off, then on again. After restarting it everything works perfectly till I goto flip mode again.
Running iMac mid 2009, 2.4ghz, 4gb ram, OS X 10.6.2, PT LE 8.0.3 and it is currently running straight into the computer's firewire port. I have not hat this issue at anytime previously.
I have tried loading the firmware again, and I am currently redownloading PTLE to reinstall.
Any tips, tricks or information?
Old 03-20-2010, 11:02 AM
Default Re: 003 fader randomly stops working.
bump
Old 03-21-2010, 11:13 AM
Bump again.
Old 03-22-2010, 12:41 AM
tamasdragon tamasdragon is offline
Once I had a problem like this, but with a repower it gone, hopefully forever.
Have you tried to re-calibrate the faders?
when in offline mode: utility-test-fader-recal
my blog:Tamas Dragon
Old 03-22-2010, 10:25 PM
Carl Fuehrer's Avatar
Carl Fuehrer Carl Fuehrer is offline
I had that a week after I got mine. Go into Utilities and do a fader Recalibrate, that brought mine right back. I hope it helps.
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 07-08-2010, 06:43 AM
This just started happening again :|
Very odd. I can make it happen pretty easily, but it also occurs at random times. It doesn't seem to be the fader itself since I can make it happen to any fader, but at the same time one particular fader does it more than others.
I've tried other FW cables, beyond that I'm pretty clueless.
Old 08-16-2010, 12:33 PM
This almost appears to be some sort of template issue. Right now the fader is controlling track volume ok, but does not respond to software control (moving fader in the mixer).
It doesn't respond to flip mode or automation either.
This is so weird
Session audio stops randomly. HELP! joedexter23 macOS 2 03-24-2012 11:47 AM
Video randomly stops playing back rnd Pro Tools TDM Systems (Mac) 0 08-23-2011 11:34 AM
Delay Compensation Randomly Stops Working edit machine Pro Tools TDM Systems (Mac) 6 11-02-2010 06:45 AM
002 randomly stops working!! reyalp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-24-2006 06:12 PM
itunes stops randomly Sunzate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-30-2005 11:20 AM
