Old 02-03-2010, 12:00 AM
TommyT TommyT is offline
Unhappy PAL Firewire Video Playback in an NTSC Studio _ ! How ?
Working on a PAL Project , But I'm all NTSC. How do I play back a PAL video to my Plasma through my Canopus ADVC100 Firewire box...
Can I do this at all ?
Switched PT to PAL Quicktime plays fine inside protools on a 2nd monitor..
Switched the #6 Canopus dip switch to PAL, but PT still has Output to Firewire Greyed out... what settings do I need to make that function... is PAL still 720x480 ? or does the quicktime need to be something else ?
do i need to use a LCD monitor with an S-video input to even see the picture ? will any American TV or monitor be able to show the 25fps PAL video ?
What are my options ?
Anyone running PAL projects with external Firewire Video...
PT 8.01 8 core intel HD3 Canopus ADVC 100 OSX Leopard..
Old 02-03-2010, 01:19 AM
farhadkd farhadkd is offline
Default Re: PAL Firewire Video Playback in an NTSC Studio _ ! How ?
You've done pretty much everything correctly EXCEPT for the fact that you TV/Display panel is probably not Multisystem capable, so cannot display PAL or SECAM. That would explain why it shows up on your dual computer monitor correctly, but not on the TV....
In the end, it comes down to 3 chords and the truth...
Old 02-03-2010, 01:20 AM
..oh and PAL in DV native format should be 720 X 576, 25fps
Old 02-03-2010, 03:47 AM
^Tripper^ ^Tripper^ is offline
I'm assuming you did everything else correctly. (frame rates etc). Did you 'reboot' the Canopus box? If you're changing the Dip switch to switch formats on the Canopus, you gotta either unplug the box and then reattach it, or just reboot the machine.
Good Luck.
________________________________
There are no carrots in carrot cake.
Old 02-03-2010, 08:20 AM
gsilbers gsilbers is offline
+1
youll need to get a multisystem tv or most likiley, work on a second computer monitor just for this project.
Old 02-04-2010, 07:14 AM
Ok so I guess i need a $200 PAL to NTSC converter to watch the canopus PAL output on my Regular TV or Plasma.... but I'm still not able to get PT to output the Pal Video out to my Canopus.... I flipped the Dip switch rebooted it & my computer but output to fire wire is still greyed out ...... the quicktime is 25 Fps 720x480 .mov
any thoughts ?
Thanks in Advance.. :)
Old 02-04-2010, 07:33 AM
nucelar's Avatar
nucelar nucelar is offline
First you got to get pro tools to output to canopus. I can't think of anything else than rescale your quicktime to 720 x 576, which is standard PAL.
After you're streaming to the canopus and still don't see anything, try browsing the setup menus on your plasma and see if there's a setting for "TV System" NTSC-PAL-SECAM-AUTO. Most modern screens should handle all formats.
Also, make sure the quicktime codec is DV-PAL!!!
Old 02-04-2010, 07:35 AM
Richard Barrie Richard Barrie is offline
It sound that the .mov is not a dv stream. This would grey out the "Play out Firewire" button.
We switch between PAL and NTSC all the time and there should not be a problem.
All of our monitors and plasmas will except both PAL and NTSC and will auto-select to the correct format.
Mojo or Canopus - firewire video playback Fritz Post - Surround - Video 4 05-25-2012 07:41 AM
DVCPRO50 NTSC video CODEC playback in Pro tools Seti Orion Pro Tools TDM Systems (Mac) 6 10-12-2008 09:53 AM
anyone using firewire video playback on xp ? audio53 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-16-2006 02:18 AM
Video playback over Firewire/DV Fraxby Tips & Tricks 13 07-18-2002 10:45 AM
Rehash w/ a twist: Video, NTSC, Firewire, FCP3 AVGuru1 Pro Tools TDM Systems (Mac) 2 05-25-2002 09:48 PM
