Pro Tools LogFiles? .dlog (pro tools crash logs!?!?)
Sorry if i've missed it somewhere but i have some issues with 8.0.3 on Snow Leopard and i see we have these dlog files generated when problems occur! First one! without any warning i get the SWOD spinning wheel of death and i have to force quit out of PT.... SWODPro_Tools_HD_2010_01_08_19_04_20.dlog.zip http://www.sendspace.com/pro/dl/c1i0l6 Second one! sometimes when closing one session and i try to open another i get the message there's not enough system resources and a list of all the plugins that can't be used, then when the session opens its all disables, no plugins and no voices etc, just a skeleton session that won't run and i have to reboot PT... NOT ENOUGH SYSTEM RESOURSES Pro_Tools_HD_2010_01_08_17_26_59.dlog.zip http://www.sendspace.com/pro/dl/j1vj5p Chris
Re: Pro Tools LogFiles? .dlog (pro tools crash logs!?!?)
I am having exactly the problem you are describing here! I'm running PT9 HD2 on a Mac Quad Core 2.66. 2 Apogee Rosetta 800's connected via X-HD. The system has been running almost flawlessly for about 6 months. Just yesterday I started having exactly the same symptoms you describe, while opening very small, simple sessions without a lot of plugins. I ran Disk Warrior on the System Drive, and on my working drive. I deleted PT prefs. I repaired permissions on the system drive. Still having the problems. Did you ever figure this out? How do you read the .DLOG files? Searching for info on .DLOG files and how to read them is actually what led me to this thread. Coincidental that you end up describing exactly my problems! Thanks! - Steve ( info [at] axissound.com ) |
Pro Tools 11 Crash Reporter - send in those crash logs! | Bob Brown | Pro Tools 11 | 37 | 01-29-2015 12:37 PM |
H E L P !! Crash Logs Here ----->>>>>>>> | RBp | Digidesign Hardware & Software | 0 | 11-23-2010 05:37 PM |
Crash Logs | pherzfeld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-21-2008 02:49 PM |
Where to send crash logs? | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-11-2007 04:38 PM |
Crash logs | Stig Eliassen | Pro Tools TDM Systems (Mac) | 2 | 03-07-2005 05:06 AM |
