Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 03-28-2008, 04:19 AM
61keys 61keys is offline
Default iLok disconnection
Hello, newbee here. Just want to know if it's ok to remove the iLok key once protools opens already? Cause my macbook pro has 2 USB only so i have to remove my ilok and connect my Midi controller keys. The other USB port is used to connect my m-audio transit interface. I have an m-audio firewire 410 and use it only at home, and when i'm on the go, i just bring and use my transit. I'm just worried what effect could happen if i continue to do so. Thank you.
Old 03-28-2008, 09:10 AM
TechKnowledgy TechKnowledgy is offline
Default Re: iLok disconnection
I'm pretty sure you can remove the iLok once Pro Tools loads because it scans it on startup; however, I don't know if Pro Tools will be able to recognize your MIDI controller if it's not connected when the program loads. You may need to get a USB hub. Make sure you connect the Transit to the port on the left side of the computer, there are known issues with using audio interfaces on the right port. Then connect the iLok and controller to the hub on the right side.
Old 03-28-2008, 03:37 PM
Thanks a lot, i'm actually connecting my transit on the right side and ilok on the left. No issues so far but i won't wait for one, I guess i have to switch it next time.
Plugin auth weirdness - guest iLok prevents internal iLok? Scott Helmke VENUE Live Sound Systems 3 09-07-2011 07:06 AM
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-07-2009 03:51 AM
Transfer iLok auth. from old iLok to new 003 factory iLok? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2007 07:05 PM
Digi002 Rack disconnection problem while recording brandin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-13-2005 08:27 PM
Digi 002 and Logic JITTER AND DISCONNECTION entice77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-09-2005 11:06 AM
