MBox 2 Pro- quick question from prospective buyer
Hi. I mostly play keyboards. Am I correct to say that you can plug in two 1/4 inch stereo inputs (or I guess four mono 1/4 inch inputs) into the MBox 2 Pro for simultaneous recording? Thanks in advance...love the forum!
Re: MBox 2 Pro- quick question from prospective buyer
Yep. Go to the Digidesign.com, and read-up on the Mbox models. Pretty through info and specs. Ditto on the computer compatibility pages. A bit of research now will save you trouble later.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Technically, no. AUX In (Analog In 3-4 in Pro Tools) are Line level Inputs (Tip-Sleeve) with Trim knob on front panel. DI 1 and DI 2 on front panel are Tip-Sleeve Inputs only that require -20 dB pad to be engaged. Mic/Line In 1 & 2 are combo jacks for XLR or Tip-Ring-Sleeve connections only on rear panel. But the Mbox 2 Pro does have simultaneous S/PDIF and Analog, (coaxial) RCA, no Optical which some Keyboards support. Also keep in mind, the Mbox 2 Pro also has MIDI Time Stamping, the only other Digidesign device that has this (currently) is Digidesign's MIDI I/O.
filosofem
Aaron Mulqueen - 001 HD Native |
Thanks for the answer, but I'm a bit confused. I don't know what things like "tip sleeve" mean? So are there only two 1/4" inputs suitable for keyboards, or are there more than this of the same quality? I'm not really interested in any other inputs to be honest. Thanks.
Splitting hairs, yes, however it needed to be noted. (Mic/Line 1 & 2 on the Mbox 2 Pro (Rear Panel) are only Balanced Inputs and as far as I can work out, will not accept Unbalanced connections). filosofem
filosofem
Sorry, but I don't get this.
If you put a keyboard into the DI-inputs on the front, what happens? Nothing? Can't you put the keyboard htrough the mic lines as well as the line inputs? (Can't you somewhat connect it through spdif as well?) |
Yes, you can use DI 1 & 2 Tip-Sleeve Inputs for Keyboards but you need to engage the -20 dB Pad. As with the Mic/Line 1 & 2 Tip-Ring-Sleeve Inputs on the rear panel (which can also input TS cables) also requires the -20 dB Pad to be engaged. But the AUX 3 & 4 TS Line level Inputs do not require the -20 dB Pad to be engaged and hence a more suitable Keyboard input. The Mbox 2 Pro only has two Mono Line level Inputs, where as the 002R has four Mono Line level Inputs.
Yes, the Mbox 2 Pro has simultaneous Analog and Digital (S/PDIF) I/O's. filosofem
Downgrading MBOX 2 to MBOX mini (Quick question) | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 08:29 PM |
Prospective New User - MBox System Question | Charles Crolley | Pro Tools TDM Systems (Win) | 1 | 10-01-2003 02:49 PM |
Prospective Mbox buyer needs info on buffers | citizenchunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-11-2003 05:21 PM |
Laptop advice for prospective MBox | JeffRock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-17-2002 10:21 PM |
Questions about 001 from prospective buyer! | mahoobley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-07-2002 11:08 AM |
