Old 02-09-2016, 08:08 AM
john1192 john1192 is offline
Default Audio Import - Interleaved / Dual Mono Broken
hi, i just needed to import 50 tracks into a new session into Pro Tools 12.4 .. all files are just interleaved wav's ..
after import i noticed that some files came over Interleaved an some Dual-Mono ..
this has never happened to me and not sure how to solve this ..
yes, the option to drag Dual-Mono to Stereo tracks .. but that is not the point ..
this is NOT Working Correctly ..
i tried it with just 6 tracks and same thing ..
all tracks are interleaved - i made these myself in Cubase Pro 8
session is set to Interleaved in Session Setup Window Apple 2 ..
cheers john
NOTE: drag and drop works FINE ...
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 02-09-2016, 08:41 AM
thanos4 thanos4 is offline
Default Re: Audio Import - Interleaved / Dual Mono Broken
cheers john
I had this issue too,when someone sent me files exported especially from Cubase pro 8...
All other files from other DAWs import correctly intro pro tools 12...
Old 02-09-2016, 09:22 AM
random Dual Mono ?? i have imported these files into other DAW's and no issues .. they see stereo files not dual mono .. only pro tools uses dual mono so that is why i say it is PT .. not CP8 ...
just more stupid Avid crap
RME BabyFace Pro
RME BabyFace Pro
Old 02-09-2016, 09:40 AM
+1
Old 05-06-2016, 10:21 AM
katrinaschiller katrinaschiller is offline
Hi John,
This has just happened to me as well. I've imported interleaved tracks from a PT 12.3 session into PT 10.3.9 session, with the audio originally being printed from Cubase. There were multiple starts on the same track import, and some cues came in as dual mono, some came in as Stereo. Did you find an answer for what happened?
Thanks,
Katrina
Old 05-06-2016, 12:28 PM
David McRell David McRell is offline
Hi Community! Asking for clarification here.
Are some interleaved files remaining Interleaved and some are splitting into Split Stereo, or is Pro Tools doing something worse, like putting the left side of the sound on both channels of the track?
In the case of the latter, when you drag the Clip into the track, the left/right is okay. Correct?
Thanks,
DMc
DM
Old 05-06-2016, 12:55 PM
this had to do with Cubase not saving the files correctly or me not saving them correctly in Cubase ... it was an odd thing with Cubase for me ... not sure if this is the same thing you guys are talking about ..
RME BabyFace Pro
RME BabyFace Pro
Old 05-06-2016, 03:14 PM
Wireline Wireline is offline
I've imported ~50 tracks projects into PT 12.5 from C4 and C7.5 without this happening, so I don't believe it's a ProTools issue...
Ken Morgan
Midland, TX
It Doesn't Matter What I Did Then - What I Do Now Is What's Important
Old 05-06-2016, 03:20 PM
i had consolidated (offline bounced) some of the files in Cubase and that is where they became different ..
RME BabyFace Pro
RME BabyFace Pro
Audio import on stereo tracks instead of dual mono ? vudoo Pro Tools 11 9 06-14-2016 03:25 AM
Interleaved Import Broken? dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 2 01-12-2013 08:27 AM
making interleaved files from dual mono adam_w1 Pro Tools TDM Systems (Mac) 1 10-17-2005 05:52 AM
Quickest way to get from dual mono to interleaved Neale Eckstein Pro Tools TDM Systems (Win) 3 10-18-2003 10:40 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
