Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-30-2018, 10:47 AM
bayside bayside is offline
Default Re: Keyboard doesn't control PT functions
OK . . the avid board works on a newer MacBook Pro with no audio programs installed, but not MBP running PT. Functions like command Q work, but space bar, no. I've re-pluged, reselected inputs.
Old 11-30-2018, 01:41 PM
As I said before - PT doesn't care what computer keyboard it's getting it's commands from. That it seems to work on a newer MacBookPro with no audio programs is a fluke. Again the fact that PT works okay with the laptop's internal keyboard puts the problem on the keyboard.
What would help is if you tell us what is the EXACT 'Avid' keyboard you are using. If it's a keyboard that resembles the usual Apple external keyboard except for the keytops I'd put the onus for the problem on whoever did the keytop swap. Turn the 'Avid' keyboard over and tell us - do you see the Apple logo in the plastic underside?
Jack
QAPLA!
Old 11-30-2018, 09:42 PM
the keyboard has the colored keys, on the space bar it says . .logic keyboard.
Avid designed for PT. On the back is. . . B/N 20160607BN1-16 and nothing else.
Old 12-01-2018, 04:30 AM
Sounds like you're talking about this one: http://logickeyboard.com/shop/pro-tools-mac-2413p.html and if so it's like I said before - a standard Apple keyboard they put their own keytops on, nothing more. I'd say you have a flaky keyboard. Have you tried it in another USB port? Is the keyboard plugged straight into the MBP or through a port adapter or a hub?
Jack
QAPLA!
Old 12-01-2018, 07:20 AM
This board is maybe 3 years old. So a keyboard can just fail? It does perform some functions. Board on MBP works perfectly as well as PT
  #16
Old 12-01-2018, 08:52 AM
Yep. The keyswitch action can get tired and wear out with keys failing on a random basis. Think about it - the space bar is probably the single most used key on the whole keyboard. Plus if stuff gets dumped on it that can/will hasten it's demise.
Jack
QAPLA!
  #17
Old 12-03-2018, 06:12 AM
Well this will be the first keyboard I've seen fail. So what's your recommendation for a better keyboard.
  #18
Old 12-03-2018, 11:50 AM
Get a regular wired Apple keyboard if you can find one as Apple stopped selling the long keyboard with keypad some time ago. And learn the PT shortcuts.
Jack
QAPLA!
  #19
Old 12-03-2018, 02:39 PM
JFreak's Avatar
JFreak JFreak is offline
Apple now sells wireless keyboard with numpad, I know I'm using one
Janne
  #20
Old 12-04-2018, 02:18 AM
It appears that keyboard durabilty is the issue any ideas in that direction?
Slow functions on the Artist Control w/ PT Control firmflange Artist Series 15 11-26-2018 10:27 PM
Transport Functions C600 doesn't work hollow Pro Tools 11 1 08-16-2013 07:12 AM
Keyboard functions PT10 on MacBookPro KSD macOS 4 03-20-2013 06:40 AM
Lost Keyboard Functions Some Or All Help wolfman_rob Pro Tools TDM Systems (Mac) 2 05-15-2008 03:43 PM
What functions in PT can you control with an 02r? saloniki MIDI 2 12-01-2005 10:33 AM
