Old 02-09-2001, 12:27 AM
yellows yellows is offline
Default Serial Vs. USB
Im thinking of buying a midi interface to compliment the 001. Does anyone know if there are any advantages to serial or usb? for some reason i thought serial was faster but im not sure. thanks for your help jay
Old 02-09-2001, 12:37 AM
Lee Blaske Lee Blaske is offline
Default Re: Serial Vs. USB
This isn't a direct answer to your question, but you might want to take a look at Stephen St. Croix's article on MIDI in the latest issue of Mix.
Evidently, USB 1.0's bandwidth is fairly limited. It's possible that we might be seeing Firewire MIDI interfaces in the not so distant future.
There will probably be some major MIDI changes when OS X finally takes hold. At the moment, it's best to buy the interface designed for your application (Emagic, MOTU and Steinberg all have proprietary systems in addition to OMS).
Lee Blaske
Old 02-10-2001, 12:16 AM
thanks i read it great artical i hope this all comes about in a timly fashion. jay
Old 02-12-2001, 07:16 AM
WestPhillySoulzition WestPhillySoulzition is offline
Usb if they are optimized are very fast. midi is a very litte amount of info. Th usb is a perfect stable solution to MIDI. I have motu XT, it has never locked up, and is always on time.
I always see posts about bad timing with cerial
you decide mlan is far off
www.Subglo.com
Serial Card and Serial ATA...Good Idea or NoCigar fifty8th1 Pro Tools TDM Systems (Mac) 7 02-09-2005 11:24 PM
USB to serial adaptors or PCI to Serial.. maxserg Pro Tools TDM Systems (Mac) 2 10-29-2001 08:35 PM
MTP AV USB/OMS/Serial jepmus Pro Tools TDM Systems (Mac) 5 03-06-2001 09:57 AM
Keyspan Serial Adapter or Keyspan Twin Serial... J. S. Bach General Discussion 0 03-20-2000 09:34 AM
USB-to-Serial for USD Vadim Kouprianov Pro Tools TDM Systems (Mac) 1 11-17-1999 05:26 AM
