ProTools 11 - how to install Plug-ins into Windows 8
Hello Avid community,
I recently bought a ProTools 11 student version and because the PhaseScope plugin is missing (as noted in another thread), I was wondering how I would go about installing a Plug-In, namely Blue Cat's DP Meter, for a Windows ProTools 11? |
Re: ProTools 11 - how to install Plug-ins into Windows 8
Just run the plugin installer and you are good to go.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
plug-in... installer?
Where can I find that? |
If your interested in the Blue Cat DP Meter, then go to their website and purchase it. http://www.bluecataudio.com/Products...DPeakMeterPro/
I ran a type of installer and it "installed" a bunch of free AAX into a folder called, "Plug-Ins" under C:\Program Files\Common Files\Avid\Audio\Plug-Ins. I opened ProTools, but none of them showed up... Where should I move them into? |
The bluecat plugins works great in PT 11 here and you shouldn't have to move them anywhere if you installed the correct versions. You need the AAX64 bit Win version of the free Blue Cat bundle. If you go to the BlueCat website then download the correct version of the bundle. You find it here:
http://www.bluecataudio.com/Download/Products/ and they are NOT to be moved anywhere and if you download the wrong format they won't show up. IT should be this link here : http://www.bluecataudio.com//Vault/P...X-x64Setup.exe Best Chris
Oh!
Thank you very much. I understand what the difference was now. Before I had the files as individual files and not in folders. Got it. Thank you! |
how can i install mbox2 drivers with ableton and windows 7 32 bit without protools | johnchristmas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-06-2011 07:56 AM |
Unable to install Protools LE 8 on Windows 7 x64 | tmachin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-09-2010 08:28 AM |
full install protools 8.0.4 for windows seven 64?? | markolone | Pro Tools M-Powered (Win) | 5 | 08-05-2010 06:45 PM |
Windows 7 (64) doesn't install/run with PT cards plug!!!! | mite | Pro Tools TDM Systems (Win) | 1 | 02-06-2010 12:43 AM |
Waves Plug ins will not install in protools | rspears | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-11-2004 06:20 PM |
