Old 10-24-2013, 05:28 PM
def3mno62 def3mno62 is offline
Default Could not allocate memory for the disk cache. try lowering...
I get this error message on start up:
Could not allocate memory for the disk cache. Try lowering your disk buffer (dae buffer), disk cache size, or engine voice count. If you got this error on launch, delete your prefs and try again. (-9514)
now the solution I saw people post on this forum for this problem is try uninstalling the avid HD drivers and then reinstall them but I can't even find the Avid HD driver in the uninstall tab in the control panel. So I tryed uninstalling protools and reinstalling it and no go.
any help would be appreciated. Installing a program shouldn't be this hard I'm about to set some sh*t on fire lol. I got protools 10.0.0
SiSoftware Sandra
Computer
Model : Lenovo 20217 IDEAPAD
Serial Number : 100512*******
Chassis : Lenovo Notebook
Mainboard : Lenovo 20217
Serial Number : YB009*****
BIOS : Lenovo 74CN35WW(V1.10) 07/18/2013
Total Memory : 7.8GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz (4C 8T 3.19GHz/3.4GHz, 3.2GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC PGA947
Chipset
Memory Controller : Lenovo Core (Haswell) DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit
Memory Module(s)
Memory Module : Ramaxel RMT3170EB68F9W1600 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : LGD Generic PnP Monitor (1920x1080, LP156WF1-TLB2, 22.3")
Video Adapter : NVIDIA GeForce GT 750M (2CU 384SP SM5.0 940MHz/1GHz, 256kB L2, 2GB 5GHz 128-bit, PCIe 3.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GT 750M (384SP 2C 940MHz/1GHz, 256kB L2, 2GB 5GHz 128-bit)
Compute Shader Processor : NVIDIA GeForce GT 750M (384SP 2C 940MHz/1GHz, 256kB L2, 2GB 5GHz 128-bit)
CUDA GP Processor : NVIDIA GeForce GT 750M (384SP 2C 940MHz/1GHz, 256kB L2, 2GB 5GHz 128-bit)
Storage Devices
Seagate ST1000LM014-1EJ164 (1TB, SATA600, 2.5", 5400rpm) : 932GB (C:) (D:)
DTSOFT BDROM (681.8MB, ) : 650MB (F:)
ASUS SDRW-08D2S-U (7.6GB, USB2, DVD+-RW, CD-RW, 1MB Cache) : 7GB (E:)
Logical Storage Devices
Windows8_OS (C:) : 889GB (NTFS) @ Seagate ST1000LM014-1EJ164 (1TB, SATA600, 2.5", 5400rpm)
LENOVO (D:) : 25GB (NTFS) @ Seagate ST1000LM014-1EJ164 (1TB, SATA600, 2.5", 5400rpm)
WINRE_DRV : 1000MB (NTFS)
PBR_DRV : 15GB (NTFS)
KOTOR2_1 (F:) : 650MB (CDFS) @ DTSOFT BDROM (681.8MB, )
Pro Tools (E:) : 7GB (CDFS) @ ASUS SDRW-08D2S-U (7.6GB, USB2, DVD+-RW, CD-RW, 1MB Cache)
Peripherals
LPC Hub Controller 1 : Lenovo Lynx Point LPC Controller
LPC Legacy Controller 1 : Winbond W83687THF
Audio Device : Lenovo Lynx Point HD Audio Controller
Audio Codec : Realtek Semi 0282
Audio Device : Lenovo GK107 HDMI Audio Controller
Audio Codec : nVidia GeForce 6800 LE [NV40.2]
Disk Controller : Lenovo Lynx Point 6-Port SATA AHCI Controller
USB Controller 1 : Lenovo Lynx Point USB xHCI Host Controller
USB Controller 2 : Lenovo Lynx Point USB Enhanced Host Controller #2
USB Controller 3 : Lenovo Lynx Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Nitro PDF Driver 8 (600x600, Colour)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : Qualcomm Atheros AR8171/8175 PCI-E Gigabit Ethernet Controller (NDIS 6.30) (Ethernet)
Wireless Adapter : Intel(R) Centrino(R) Wireless-N 2230 (802.11n (HT), 104Mbps)
Power Management
Battery No 1 : LENOVO PABAS0241231 74.68Wh/5.97Ah
Operating System
Windows System : Microsoft Windows 8 Home 6.02.9200
Platform Compliance : x64
Old 10-25-2013, 06:31 AM
feliponk's Avatar
feliponk feliponk is offline
Default Re: Could not allocate memory for the disk cache. try lowering...
Pro Tools 10 isn't supported with Windows 8, you should get Pro Tools 11 or downgrade to Windows 7 Pro 64 bits.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 10-25-2013, 08:28 AM
thanks for the reply. So are you sure that if I upgrade that it will work? because I don't want to have to pay a hundred dollars only to find out that it doesn't work either
Old 10-25-2013, 09:11 AM
oh nvm I'll try the trial version of 11 to see if it works lol I didn't know there was a trial til now
Could not allocate memory for the disk cache. Try lowering your disk buffer.. slim_shady Pro Tools 10 15 05-09-2017 05:20 PM
Could not allocate memory for the disk cache.... jd_man Windows 21 07-07-2014 05:56 PM
Could not allocate memory for the disk cache problem digital2020 Eleven Rack 1 06-10-2013 12:38 PM
