Old 12-01-2018, 02:23 PM
amscheme amscheme is offline
Default Mbox 2 mini with pro tools 10.3.10
I just got pro tools 10.3.10 I am running it on Mac OS X 10.7.5 and something with my mbox doesn’t seem to be working, it says mbox 2 mini on my mbox but is an old version( in my system preferences it called in firmware 1.4) I downloaded drivers and the mbox light comes on but in a session I can’t set up an input for any track, I have researched mbox compatibility and I can’t find a solid answer, if I need to buy an updated mbox I’m not opposed to it just need to know if that’s what I need can anyone help?
Old 12-01-2018, 02:30 PM
Default Re: Mbox 2 mini with pro tools 10.3.10
what exactly is the Pro Tools playback engine set to? And what input have you selected in the track IO input selector?
An easy way to see what you are is to have Built In Output selected as the Play Back engine by mistake.
Old 12-01-2018, 02:40 PM
Ok I will try that in a few minutes, I hope your right, thanks
Old 12-01-2018, 03:59 PM
Southsidemusic's Avatar
As Darryl said and you can also goto settings and choose i/o and ln that page press default tab on the in and out option.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-01-2018, 04:28 PM
To be clear do what Christoper is saying only after you get the playback engine set correctly and still have problems.
Old 12-01-2018, 04:30 PM
You guys are life savers, worked like a charm thank you so much
Old 12-01-2018, 04:33 PM
You are welcome, it’s a really common mistake.
One way of avoiding this is hold down ‘N’ as Pro Tools starts until you see the playback engine dialogue, and make sure that select the correct playback engine is selected.
Old 12-01-2018, 04:41 PM
Glad you got it working again
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-02-2018, 04:00 PM
Mbox 3 mini and Pro Tools 11 sammarshallmusic Pro Tools 11 0 01-18-2015 01:14 PM
Pro Tools 8 LE with MBox Mini CyberWrek Getting Started 0 09-27-2013 02:45 PM
mBox Mini and Pro Tools 10 WernerF Pro Tools 10 8 07-20-2012 11:36 PM
My first day with mBox 2 Mini/Pro Tools 8 Le eliezering 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-07-2012 04:47 AM
Pro Tools le 8 / mbox 2 mini Mixer123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-20-2010 11:11 PM
