Old 08-04-2004, 11:33 AM
saifir saifir is offline
Default 3rd party midi interface not compatible on G5?
So...I was in a session last week on a rather new "compatible" G5 using Mbox an PT LE 6.4.
To my dismay I was having problems with clitchy audio when overdubing @ 256 and 512.. hmmm
The latency is horrible @ 1024 buffers (unusable really) 512 (when it kinda worked) caused a
modulation effect and even printed to the new audio file (sounded like a D-Fi plug-in or something)
This was real bummer and I lost a client due to these unexceptible anomilies.
After my client left in a huff to go fininsh up his project at a Logic Audio studio..I desided to
read up on the compato docs to see it I missed any thing..
Sure enough in black in white the compato docs read something like: G5's are not compatible with 3rd
party MIDI interfaces, Digidesign suggest to purchase a MIDI I/O.. this is totally lame.
- Thanks Digi
- saifir
Old 08-04-2004, 11:40 AM
Thresholdproductions Thresholdproductions is offline
Default Re: 3rd party midi interface not compatible on G5?
I have a miditime piece and it seems to work fine. A lot of people use the Motu MTP, I would highly doubt its not compatible.
J
Old 08-04-2004, 02:05 PM
I do have a control surface but even with it off and unpluged I still have problems.
From the compato Docs for G5:
System instabilities and performance issues can occur when using MIDI control surfaces in conjunction with Pro Tools 6 and 3rd party MIDI interfaces. For best multiport MIDI performance, we recommend using Digidesign's MIDI I/O.
Old 08-07-2004, 10:41 PM
nedorama nedorama is offline
Hmm. doesn't Make a lot of sense. I have a Emagic AMT8 and it works great with Digi 002R, both on a Dual 500 G4 and now on a dual 2Ghz G5.
What brand do you have that "doesn't work" with your G5? I know I had to ditch my Opcode Studio 4 because of the serial interface, but I've had no problems on the AMT8.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Old 08-07-2004, 10:45 PM
To be clear, here's exactly what the compatability docs say on MIDI interfaces:
MIDI Interfaces
Built-In
The Digi 002 includes a built-in MIDI interface with 1 MIDI In port and 2 MIDI Out ports, providing up to 16 channels of MIDI input and up to 32 channels of MIDI output. (only with Digi 002, cannot be used as a standalone MIDI interface)
Additional — USB Only
The following MIDI Interfaces are also qualified for use with Digi 002 systems with Pro Tools LE version 6.4 software for Mac OS X:
Digidesign MIDI I/O - USB MIDI interface with 10 MIDI I/O ports, supporting 160 MIDI channels
Emagic AMT8/MT4
Roland MPU64/UM2/UM4
Known Incompatibilities & Issues
Only USB MIDI interfaces are compatible with Pro Tools systems for Mac OS X. Modem-to-serial port adapters and serial MIDI devices are not supported.
System instabilities and performance issues can occur when using MIDI control surfaces in conjunction with Pro Tools 6 and 3rd party MIDI interfaces. For best multiport MIDI performance, we recommend using Digidesign's MIDI I/O. (only if additional MIDI ports are required beyond the 16 in/32 out built into the Digi 002)
So while it says that the MIDI I/O works well, it also says USB only. Where they say qualified means they've tested it extensively, but it's by no means a be all end all list.
Regards,
Ned
Monkey Boy Studios
PT 9 and 3rd party midi/audio interface darkglass Pro Tools 9 3 11-19-2010 07:07 AM
What's the best MIDI interface ie what's compatible sircharles2 MIDI 0 08-09-2007 08:26 AM
Using 3rd party Midi Interface - Emagic MT4 projectmk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-08-2005 09:00 AM
POLL: Best 3rd-party MIDI Interface? primafacie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 08-01-2003 12:24 AM
3rd Party MIDI Interface/PTLE MIDI Survey Numachida 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-13-2002 02:50 AM
