Old 04-19-2016, 09:13 AM
idris idris is offline
Default Re: X-form and pitch shifting
Originally Posted by minister View Post
Don't use a Time/Pitch plugin for FPS changes. Rather, use SRC, it is more accurate and sounds better.
SRC gets the duration correct, but how do you correct the resulting pitch change? Are you using something other than PT's own SRC, or are you just ignoring the pitch change?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 20yrs experience in TV. Currently mainly indie features.
Old 04-19-2016, 10:18 AM
Reckless Erik Reckless Erik is offline
I use SRC to get the fps changes right. Then Time Factory to do the pitch conversions. Best to pitch stems and not a final mix. Then let the stems render out a mix (using offline bounce).
nickcath@internet.is
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.14.6, PT Ultimate 2020.9.1 HDn, Avid Artist Control, Avid Artist Mix...,
MacPro 3.5GHz 6 core 64GB RAM OSX 10.14.6, PT Ultimate 2020.9.1 HDn, Avid Artist Control, Avid Artist Mix, PT Dock...
Old 04-19-2016, 10:54 AM
I use the same workflow. I'm just not happy with the tools I've got to pitch shift, especially on Dx. (And as the demo of TimeFactory doesn't let you export, it's a PITA to A/B it's output with other pitch shifters. Harumph!)
Old 04-19-2016, 12:13 PM
minister's Avatar
minister minister is offline
This is what I do. Except, I use X-Form. It's slow, but I have been happy with PAL to FILM or PAL to NTSC or FILM to PAL.
For NTSC to FILM or vice versa, who cares about the .1% pitch....
Some day would like to try Time Factory
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 04-19-2016, 03:37 PM
garret garret is offline
I've been banging on about zplanes elastique for the last few years on here and Gearslutz. I haven't heard better and it will do an amazing job on a full mix as well should you need to.
IMDB
  #16
Old 04-19-2016, 11:52 PM
lode lode is offline
Reckless Erik: Why do you src first, and then pitch correct in Timefactory instead of just time-strecth in Timefactory? Seems like a longer route to get to the same place. Or does Timefactory sound better when pitch-changing than when it is time-stretching?
garret: I´ve never heard Elastique. Have you compared it to Timefactory?
PT 10.3 & 11
Mac 2x2.26 Ghz quadcore 6 gig ram
HDX 1 via Omni
Blackmagic Intensity Pro
Waves Broadcast/Production, C4 & NPP
Izotope RX, Altiverb
  #17
Old 04-20-2016, 02:38 AM
Schottlandru Schottlandru is offline
SRC will give you 100% sync, whereas the time-stretching algorithms usually shift about to make things fit as they feel works best for them.
Users here have reported times being off by a frame or more.
I remember doing a shootout between different tools.
I preferred Nuendos realtime shift which is based on Elastique.
But a question: My main issue with all algorithms is a certain grainyness in the sound, esp. dialog. You could also call it rough.
Any tips on what might be causing this? Would be very greatful for anybody sharing!!
My findings: tools are either good for long, bassy or paddy sounds and grainy/metallic on transients, or they are better for transients but hiccup and blip on those bassy, long sustained sounds.
I once tried PitchnTime which wounded great on the mix up to when the music came in... it stares warbling the pitch up and down like a record left out int the sun and going oval shaped. Totally surprised me as the settings where clearly only shifting for pal to film, and I immediately lost trust in the tool. Thisnwas freelancing somewhere else, so no time to repeat yet...
  #18
Old 04-20-2016, 05:40 AM
Ok. So it handles sync better when pitch shifting than when timestretching?
PnT works great in V mode for adjusting ADR. Not so much however for fps conversion.
PT 10.3 & 11
HDX 1 via Omni
  #19
Old 04-20-2016, 06:20 AM
If you had V mode on in pitch n time it mangles everything but dialogue. But the other modes which sound good on music and fx really mess with the dialogue! Basically it can't be used on a full mix. It does however work pretty well on individual stems. I'm taking about pitching only. SRC separately as previously described.
IMDB
  #20
Old 04-20-2016, 09:22 AM
john1192 john1192 is offline
x-form ... another good but abandon product from Avid .. when is the last time we had an update for X-Form .. some of us paid 500.00 for x-form when it came out .. now worth 39.00 LOL
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
HTML code is On
Pitch shifting bontay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-15-2008 11:55 AM
Time shifting/pitch shifting? mistasmijen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2008 04:24 AM
Pitch Shifting danika 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2007 08:15 PM
Pitch Shifting Add - On SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2006 12:09 PM
25-24 fps pitch shifting. Does anyone know? Kenan Akkawi General Discussion 1 07-23-2001 05:10 AM
