Old 07-30-2011, 02:15 PM
headsup headsup is offline
Default Shortcut to Select Next/Previous Track
Hi all,
Does anyone know how to map a keyboard shortcut to move between tracks?
ie. Next Track & Previous Track similar to the buttons on Axiom Pro only with a Keyboard?
Thanks
H.
Old 07-30-2011, 03:15 PM
Default Re: Shortcut to Select Next/Previous Track
Off the top of my head, I believe not. Axiom Pro does this function very well. Ummm... Track Numbers might be a suitable workaround.
Aaron Mulqueen - 001 HD Native
Old 07-30-2011, 05:01 PM
formfunction formfunction is offline
Originally Posted by headsup View Post
Hi all,
Thanks
H.
Dont have an Axiom.. but to scroll between tracks the (p) and ( keys get you up and down in the edit window... and selects track groups.
and previous selection ( opt-cmmd-z) will get you back to a track so long as you have only done one selection on the current track. ff
Old 07-30-2011, 05:11 PM
Move Edit Selection Up and Down - Keyboard Shortcut P and ; is that the Edit Selection is selected in a track and that Link Track and Edit Selection is enabled. Not always practical.
Old 07-30-2011, 06:32 PM
cneal92's Avatar
cneal92 cneal92 is offline
I often use the Scroll to Track shortcut Cmd-Opt-F (mac), which opens a dialog and you can enter the track number. This works well in combination with the Link Track and Edit Selection enabled. You can then also use the P and ; as previously mentioned to move the selection around. Al
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: cneal@southplainscollege.edu
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 12-11-2011, 06:20 AM
Thanks Chris, this worked. Now that I have the Axiom Pro its all built-in, dream come true!!
Old 12-11-2011, 07:59 PM
Ain't it.
Old 02-21-2012, 12:36 PM
the hecksome the hecksome is offline
Command Option F is a good one, thanks for that. Is there a shortcut that allows you to select the track that the cursor is already on? I use p l ; ' for moving the cursor frequently, but once I discovered that the track has to be selected to use the new playlist shortcut, command \ I realize I need a select track shortcut too...
Old 02-21-2012, 02:23 PM
Ok, duh, so just click on link track and edit selection at the top of the edit window.
Success!
Shortcut help - snap to previous / next? Jakob Clemen Tips & Tricks 4 03-16-2016 03:13 PM
Surround Panner 'select track' shortcut? aasteveo macOS 0 02-19-2013 01:04 AM
Keyboard shortcut for selecting next / previous track in Mix window? spinsah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2009 01:37 PM
"select next/previous track" "rec enable track" key command? maufau Pro Tools TDM Systems (Mac) 6 04-22-2008 06:08 PM
Previous/Next Shortcut for Expand??? John Pisciotta Virtual Instruments 0 06-13-2006 09:37 AM
