Removable Drive Bays
I have been looking for some removable drive bays for a while and I recently heard about the ones from Inclose Design. Well, I was about to order them when I decided I would take a quick look at my G4 to make sure it would work. The DVD-R is in one 5.25" drive bay and the other is holding my second IDE hard drive. Well, to my surprise it looks like its actually only a 3.5" slot. Its not actually another 5.25" drive bay which is needed for the removable drive bays that I was looking at. Can someone help me out and lead me in the right direction. All I need is IDE drives and I need to swap them out cause I use different systems and I need to import sessions fast.
Jason
- Jason |
Re: Removable Drive Bays
External Sarotech Firewire IDE boxes .... hot swap and fast enough.
Remember to take the required software with you when you go to a new machine. I use these for PT sesion and FCP stuff. |
Yeah, it looks like I will have to go Firewire even though I didn't want to. I have two other workstations that aren't equipped with Firewire ports. Do you know if anyone makes a external Firewire bay that accepts the removable drive bays so I would be able to pull them out and the slide into the drive bays on a normal 5.25" PC equipped with the docking bay? Cause that would be the best solution for me now.
Jason
- Jason |
mmmmm??
are you saying you want to exchange between PC and Mac.....? When I do this I tend to use a drive to put a session onto to move to the other system and then put the session onto the Audio Drive in that machine. I have never used the same drive on PC and Mac for one session ??? did that make sense? not sure I can help. [img]images/icons/frown.gif[/img] |
Removable drive recommendations | skylab001 | Pro Tools TDM Systems (Mac) | 8 | 04-20-2009 09:16 AM |
In MacPro, are drive bays 2-4 as reliable/efficient as bay 1 (for startup drive)? | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-07-2009 03:57 AM |
removable drive bay for G4 | slinky | Storage Subsystems | 8 | 03-11-2001 04:45 PM |
ORB CASTLEWOOD ReMOVABLE DRIVE | Fom | Pro Tools TDM Systems (Mac) | 1 | 03-18-2000 06:59 PM |
One removable drive for Mac & NT | sidereal | Storage Subsystems | 1 | 05-26-1999 12:34 AM |
