  #101
Old 03-25-2013, 12:52 PM
sonnie sonnie is offline
Default Re: Pro Tools 10 on Windows 8??
Well, I tried PT10 on my Win7 (prof) 64 Bits Bootcamp and its works quite well. The idea was, that I'd maybe waste money when I buy a Win7 ultimate instead of Win8.
PT 10.3.4 CPTK | Reaper 4.32 | Mac Pro 1.1
  #102
Old 07-16-2013, 07:36 PM
jjnssn jjnssn is offline
Originally Posted by Shan View Post
It will work but it's not supported by Avid, hence you're on your own if you have problems. To get the Disk Cache going(-9514 error), you'll have to do this:
http://msdn.microsoft.com/en-us/library/ms190730.aspx
It's one of the privileges needed that the PT 10 installer doesn't include at this time.
You can get W7/W8 64-bit running on a Mac Pro 1,1 but you'll have to create a custom install disk. Not a massive or difficult procedure, but definitely an advanced step if you've never done it before.
Shane
Shane,
could you tell me, is this required with PT11.0.1 as well? With this change does a guy still have to run in W7 compatibility mode during setup?
Thanks,
J
  #103
Old 08-08-2013, 08:49 PM
jbkleyla jbkleyla is offline
No it is not required. PT11 installs normally and works fantastic on Windows 8. I have both PT10 and 11 installed and I must say 11 is so much better to work with on Windows 8.
Pro Tools 11 on Windows 7 or Windows 8? ianbee Windows 6 08-15-2013 04:04 PM
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) miek07 Windows 3 07-26-2012 07:49 PM
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 04:22 PM
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system rhodamorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-21-2010 05:31 PM
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2009 08:24 PM
