Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 09-11-2013, 07:04 AM
peteage peteage is offline
Default Recorded audio placed 40ms too early
PT10 + Focusrite Scarlett 18i20 (USB) loopthru test, PT places tracks 40ms early! Has anyone found a way of fixing negative latency issues?
Guess this must be latency overcompensation or else I have accidently invented a time machine!
Can get the over compensation down to only 300 samples early by setting minimum buffer and no compensation but cant achieve zero (unfortunately running min buffer is no longer glitch free).
How can I modify PTs default assumption about USB latency to achieve sub negative (ie. zero) latency on recorded tracks?
Do we expect PT to be able to run with popular 3rd party ASIO/USB interfaces?
Any tweak advice or known work around for this would be very much appreciated. I have had enough of manually nudging all recordings into synch!
Thanks in advance,
peteage
SiSoftware Sandra
ID Host Name : yogi
Workgroup : WORKGROUP
Computer
Model : Acer Aspire 5742Z Intel_Mobile
Serial Number : LXR4P021931***********
Chassis : Acer Notebook
Mainboard : Acer Aspire 5742Z
Serial Number : Base Board S************
BIOS : Acer V1.18 03/14/2011
Total Memory : 3.68GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Pentium(R) CPU P6200 @ 2.13GHz (2C 2.13GHz, 1.73GHz IMC, 256kB L2, 3MB L3)
Socket/Slot : FC PGA988
Chipset
Memory Controller : Acer TravelMate 5742 133MHz, 4GB DDR3 SO-DIMM 1GHz 64-bit, Integrated Graphics
Memory Module(s)
Memory Module : Nanya NT4GC64B8HB0NS-CG 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : LGD Generic PnP Monitor (1600x1200, LP156WH2-TLEA, 15.7")
Monitor/Panel : OEM 42_LCD_TV
(1920x1200, 7.2")
Video Adapter : Intel(R) HD Graphics (12SP SM4.0 667MHz, 258MB DDR3 1GHz 64-bit, Integrated Graphics)
Graphics Processor
Storage Devices
WDC WD3200BPVT-22ZEST0 (320.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 298GB (C:)
Seagate ST1000LM024 HN-M101MBB (1TB, USB2/SATA300, 2.5", 5400rpm, 8MB Cache) : 932GB (E:)
PIONEER DVD-RW DVRTD10RS (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
SYSTEM RESERVED : 100MB (NTFS)
MusicDrive (E:) : 932GB (NTFS) @ Seagate ST1000LM024 HN-M101MBB (1TB, USB2/SATA300, 2.5", 5400rpm, 8MB Cache)
Acer (C:) : 283GB (NTFS) @ WDC WD3200BPVT-22ZEST0 (320.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
PQSERVICE : 15GB (NTFS)
Optical Drive (D:) : N/A @ PIONEER DVD-RW DVRTD10RS (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Acer HM55 LPC Interface Controller
Audio Device : Acer P55/PM55/3400 High Definition Audio
Audio Codec : Realtek Semi High Definition Audio
Disk Controller : Acer P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : Acer P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : Acer P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Lexmark C920 Series PS3 (600x599, Colour)
Printer : Epson Laser ESC/PageS (600x600, Colour)
Network Services
Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet (Ethernet)
Wireless Adapter : Atheros AR5B97 Wireless Network Adapter (802.11n (HT), AES-CCMP, 144.4Mbps)
Power Management
Battery No 1 : PANASONIC Li_Ion_4000mA 47.52Wh/3.87Ah
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 3.8
MC^3
Old 09-11-2013, 11:02 AM
Craig F Craig F is offline
Default Re: Recorded audio placed 40ms too early
what is your input routing like? are you trying to record through plug-ins?
Thank you,
Craig
Old 09-11-2013, 11:21 AM
jimst57 jimst57 is offline
I had the same problem.
I solved it in the mix window. Make sure the delay compensation is showing at the bottom of each track. There's a box in there where you can enter a value. Positive or negative. I just tried different values until the audio lined up.
Old 09-11-2013, 08:05 PM
This is(unfortunately) a "less than supported" computer. Pentium single core(not good), 4GB of RAM(the minimum), integrated graphics(not so good) and you do not have an approved(7200 rpm) recording drive. What plugins are in place in your session(especially on the master track). What buffer are you running at, and is Delay Compensation on or off during recording? Try disabling wifi when running PT.
HELP!! PT10 Latency overcompensation places odub tracks 40ms early peteage FireWire & USB Audio Interfaces (Win) 0 09-09-2013 04:11 PM
Recorded audio playing back too early jonwade92 macOS 3 04-15-2013 01:01 PM
Midi recorded early allstaar macOS 2 05-09-2011 03:27 PM
Recorded audio too early in relation to backing track MagDee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-23-2011 04:23 PM
Recorded Audio Not in Time bug Audio always early Hawkeye Pro Tools TDM Systems (Mac) 6 10-20-2005 11:57 AM
