Old 05-14-2011, 08:12 AM
ZZR1100 ZZR1100 is offline
Default Upgrade question
Hello all
First post - I've searched for the answer first but I can't see it so here goes...
I've recently bought PT 8.0.5 LE with an Mbox 2 Mini. It doesn't have timecode/OMF features. DV toolkit is at least 400 GBP (as far as I can see).
However, Pro Tools 9 (crossgrade from LE) is on eBay for 120 GBP.
So I have 3 questions:
1) Will that crossgrade to PT9 work with what I've got?
2) Will all my existing plugins work with 9?
3) Is there any way I can keep both versions installed?
Thanks!
MacBook Pro 2.2 gHz, OS X 10.6.7
Pro Tools 8.0.5 LE
Mbox 2 Mini
1 tb Miglia DualDisk hard drive
PreSonus Faderport
Old 05-14-2011, 08:31 AM
nst7 nst7 is offline
Default Re: Upgrade question
Yes, it will work with your Mbox mini.
As for your existing plugins, if they're the ones that came standard with Protools, they will simply be installed again when you install 9.
For third party plugins, you'll need to check each manufacturers website to see if there are any new updates for compatibility with PT9.
As for keeping both versions installed, you're really asking for trouble.
9 works great, I recommend doing a complete uninstall of 8 before installing 9.
And going for 9 is a better option, as it has the functionality of DV Toolkit built in, and there's no point in paying for a discontinued product (dv toolkit) unless you knew you were going to still be on 8 for quite a while.
However, there may be one advantage to getting the DV Toolkit, and that's the fact that you can then upgrade to Complete Production Toolkit 2 for only $299 U.S. If you were thinking about getting that eventually, then you might want to take advantage of that, which would give you surround mixing capability.
Regardless, though, I would still recommend upgrading to PT9.
Old 05-14-2011, 10:25 AM
Thumbs up Re: Upgrade question
That's what I call a comprehensive answer!
Thanks very much.
Mac Studio M1 Max 32gb
Pro Tools 2023.9
Ventura 13.6.6
Focusrite Clarett+ 8Pre
Mac Upgrade Question Rayvenx2208 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-24-2010 08:53 AM
Upgrade question - can I use mbox2 micro upgrade on 002 system? spreston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2009 11:22 AM
Upgrade to 003 question Jamtime 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-29-2007 02:42 PM
To upgrade, or not to upgrade? 'Tis the question.. knewbee Pro Tools TDM Systems (Mac) 5 03-07-2005 09:09 PM
to upgrade or not to upgrade, that is the question paul m 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-06-2004 12:01 PM
