Saving amplitube inserts not working
I have downloaded the Digidesign fix for saving amplitube settings in a session, but the results have not changed. Everytime I close and save a session with Amplitube inserts the session does not really save the Amplitube settings that I inserted into the session. Am I missing a step? I thought that the Digidesign fix would save the Amplitube inserts and keep me from having to add each insert for each track every time that I re-open a session. If you have advice...please let me know. Thanks in advance....
Re: Saving amplitube inserts not working
Choose the other option Digi says to choose when installing the fix. I'm sorry but I don't remember.....if they say modify, select repair.....if they say repair, select modify. If you do the opposite, it will work. Good luck, Jason
P4 3.2,ABIT IC7,875P chipset,512 Ram,Digi 002,LE 6.7 www.jasonwhinnery.com [email protected] |
What is the name of this patch?? I never saw it anywhere (thought that amplitude just plain sucked for that reason)
Well....I tried the opposite...(inless they corrected it before I did the opposite). I repaired instead of modifiied the install...and it didn't work. I'll try the opposite and see if it works, (the opposite of the opposite?) Anyway....I hope that I can find the fix for this ... it would make session amendments alot easier. Thanks for your input!
The patch is not on the IK Multimedia website....it's a Digidesign fix. You can find it in Digidesign's downloads. I just need to figure out how to make it work.
Would like to comment...
Digidesign has the best customer support for a product, (Digi 002), that I heave ever seen! I had a problem with my 1394 ports...and Digi fixed the problem in a quick and professional way. I was very pleased with the service and am very glad that I bought the Digi 002. My thanks to Digidesign for the great customer service that I received! Richard E. South Texas |
Can they get that "save" to work on the plugs?
Share the gift gifted to you |
The update is available on both the IK and Digidesign site's.
You have to login to the User area to access it on the IK page. Here's a link to Digi's: http://www.digidesign.com/download/plugs/bun/ Choosing the "Repair" option worked for many of us. |
Plug-ins Inserts Missing in MIX? After saving. | ircswh | Virtual Instruments | 2 | 01-22-2007 03:58 AM |
Amplitube settings not saving | rkohli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-06-2005 12:11 PM |
Amplitube not saving | jauk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-01-2004 09:09 AM |
amplitube not saving settings | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-01-2003 03:01 AM |
Amplitube not saving plug in settings? | Michael Carpenter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-23-2002 09:34 AM |
