Old 01-30-2017, 01:24 AM
yoerik roevens yoerik roevens is offline
Default S3 bug: track exits trim mode after writing send automation in preview mode
to reproduce:
- disable 'include sends in trim mode' in preferences/mixing
- have a track with an active send in touch/latch/write mode AND trim mode
- enable automation preview mode
- adjust send level and write using write to selection/start/end
-> track now exits trim mode
happens on the S3 but works fine on D-Command
Old 02-20-2017, 12:51 PM
yoerik yoerik is offline
Default Re: S3 bug: track exits trim mode after writing send automation in preview mode
mroe specific: this only happens when wrting automation during playback. when writing automation when playback is stopped, it works fine
Old 06-27-2017, 12:57 PM
I just made a little video showing exactly what's happening:
https://drive.google.com/open?id=0B2...XotNWd5aUQ2NEU
This is PT12.8 but this has been around in all PT versions as far as I can remember.
EDIT: same video on dropbox as google drive seems a bit iffy: https://www.dropbox.com/s/izelwz5qzw...13358.mp4?dl=0
Old 06-27-2017, 06:09 PM
EddieJones's Avatar
What is your Coalesce Trim Automation Options pref set to ? Is it Manual ?
Old 06-27-2017, 10:38 PM
It's set to 'after every pass'. But this is interesting: when I set it to either remaining mode (man/on exiting trim), the same thing happens, however the channel only gets out of trim mode as soon as I stop playback (instead of instantly when I hit 'write to all').
Thanks again for chiming in!
Automation - preview mode - shortcut Mark Norup ICON & C|24 10 01-23-2015 09:51 AM
Send Group Trim Mode? Why not working? Daniel Sasso Pro Tools TDM Systems (Mac) 0 12-17-2009 07:52 AM
Automation... Trim Mode in LE/MP? maufau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-19-2008 03:49 AM
Trim automation mode: what is it for? cinetj Pro Tools TDM Systems (Mac) 3 02-25-2008 05:34 PM
Aux Send behaviour in trim mode Version 6.9 Desert Fish Pro Tools TDM Systems (Mac) 1 06-14-2005 05:12 PM
