Old 04-20-2004, 11:13 PM
Iceberg-Slim Iceberg-Slim is offline
Default PC to MAC Differences in PTLE? (Ex /Current Users)
Was thinking of making the jump,(looking at the new powerbooks) so far I have learned that oms patchnames are mac only , sucks considering I have a bunch of sound modules
Anything else that is an advantage in the Mac version rather than the PC?
Old 04-25-2004, 05:10 PM
Default Re: PC to MAC Differences in PTLE? (Ex /Current Users)
bump
Old 04-25-2004, 05:38 PM
Chris Cavell Chris Cavell is offline
You nailed it, patch names is the biggest "benefit" to macs IMO. In LE, mac vs. pc for all other things is pretty much user preference...I use both mac and pc and have to say that I prefer my PC LE rig to my Mac LE rig...but it really is just personal preference and little more. One other advantage (albeit slightly less every day) is that there currently exist more mac compatible plugins...(that's if you don't count vst wrapped plugs.) The primary advantage to PC for LE is $$$...both platforms are equally capable of providing you with enough power for mixing slightly complex sessions.
Cavell Studios
Old 04-25-2004, 07:25 PM
Chris Shaeffer Chris Shaeffer is offline
Be very careful when buying a PC for Pro Tools. Make sure it meets all the compatibility reqs. A major advantage that Macs have is that with fewer variables its more stable. On the right PC, PTLE is stable as it gets, but the wrong PC can cause strange problems with no way to fix it.
I also wonder if updated versions of PT will run on the same PC hardware. Again, with fewer Mac models to develop and test for (and a larger share of Mac users), the advantage here goes to Macs. That may certainly change, but I think its still true at the moment.
That said, I use both. If the PC works, then it works and there really aren't that many functional differences between Pro Tools on PC and Mac. I don't use the MIDI features that much so maybe I just notice it missing on the PC, though. If I did get that set up on the Mac then I'd probably miss it on the PC.
Take care,
Chris
Old 04-26-2004, 02:07 AM
antiphase antiphase is offline
little things are already available for mac LE users.........we can import mp3, and have the DV out firewire port option, and probably a few other options I'll find out one day. PC users are S.O.L.
www.soundgeekproductions.com
Old 04-26-2004, 06:47 AM
Ultraslide Ultraslide is offline
CoreAudio support on the Mac is much better than the Wave driver for PC as far as the Digi hardware is concerned. Other then that, I dont see much difference in my rigs. I really dont do much with midi, and I try to keep my plugins the same on both machines.
the 'slide
Powermac G4 DP1.25 002R PTle 7.4
Powerbook G4 1.5 Mbox PTle 7.4
Of interest to current users? SZE Aspera DigiDelivery 1 12-06-2016 12:01 PM
PTLE vs PTHD 32/48 bit differences... acmost 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-28-2006 11:48 AM
former/current ASUS K8V SE DELUXE users mic224 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2005 10:16 AM
Software differences between PT M-Powered & PTLE sevendustweb Pro Tools M-Powered (Win) 1 11-03-2005 02:45 PM
Windows or Mac - PTLE differences??? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-27-2001 11:25 PM
