on/off Dynamic CPU Processing: AAX 3.0?
UPDATE: Solved! Thanks Stig Eliassen
Is it possible to switch Dynamic CPU Processing on/off?
Re: on/off Dynamic CPU Processing: AAX 3.0?
Setup (menu) > Playback Engine > Dynamic Plug-In Processing.
I think you should use all processors it better. And i just know that waves plug-inns are using everything and all memory for example: waves H delay it's enough to use three or four of them and computer getting crazy slowly so its better to use delay and reverb by aux. maybe my answer wouldn't help you, but i have almost same problem and making this helps kinda.
Sent from my iPhone using Tapatalk |
Glad I could help. Let us know how you get on.
HEAT + Dynamic Plug in Processing in 12.6 | T-Low | Pro Tools 12 | 0 | 09-29-2016 12:44 PM |
Dynamic Plugin Processing ... Waves ? | T-Low | Pro Tools 12 | 5 | 08-21-2015 11:44 AM |
Dynamic Plug-in Processing Question | quantise | Pro Tools 11 | 1 | 03-13-2014 09:05 AM |
Is Dynamic Plug-in Processing messing up some VI's | Touchwood Studios | Pro Tools 11 | 2 | 11-19-2013 02:09 PM |
