Old 05-06-2003, 06:28 PM
dmaxj dmaxj is offline
Default plugins on master fader...
I am applying the stock compressor and limiter to my master fader.
Does it matter which goes where in the plug-in chain. Right now I have the limiter on top and the compressor directly under on the stereo master fader...
Any advice helps...
Peace
Old 05-06-2003, 06:34 PM
jodyjfk jodyjfk is offline
Default Re: plugins on master fader...
Trying to get a hot mix, huh?
It depends on how you have each one set. If the limiter is limiting so much that the compressor never kicks in, you wouldn't need the compressor. In general, I probably would have the limiter last in the chain.
Old 05-06-2003, 06:39 PM
Aussie169 Aussie169 is offline
I generally put the limiter last.
I leave the first spot free for last minute unforseen plugs
then EQ
then Imaging (if at all)
then comp (if at all)
then limiting
Old 05-06-2003, 06:49 PM
where02190 where02190 is offline
Be advised, inserts on the master fader are not really inserts, as they are all POST FADER!!!!!!!!
Hope this is helpful.
Old 05-06-2003, 07:01 PM
Okay, thanks
So , I guess the the 'inserts' are read from the top to bottom....
Right now I have
LIMITER
COMPRESSOR
Does this mean that the signal is going thru the limiter first and then the compressor?
Old 05-06-2003, 07:04 PM
correct
Old 05-07-2003, 02:26 PM
Actually to be more specific, and at the risk of repeating myself, you'd be going Master Fader-limiter-compressor.
Old 05-08-2003, 02:33 AM
Travis Mitchell Travis Mitchell is offline
Yes, what order the plugins are in matters. Not in the sense that there is a "right" order, but that the result will be different according to what order you have the plugins in.
Old 05-08-2003, 08:43 AM
okay,
where, I am hip about the plugins on the master fader actually being post-fader...
Thanks 2 all...
DSP Plugins on Master Fader are being repurposed as Native Mixchump Pro Tools HDX & HD Native Systems (Mac) 2 12-16-2012 08:47 AM
Plugins on Master Fader or Main Mixdown Track studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-20-2007 01:02 PM
major issues with master fader plugins and PT satchvai Tips & Tricks 4 04-05-2006 07:57 PM
How do I get more than 5 plugins on Master Fader? curve666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-13-2004 02:05 PM
What are everyones PlugIns used on the Master Fader? PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 09-01-2002 07:03 PM
