Mono Send with Stereo Return via Insert
Hello,
I am interested to know if it is possible to have a mono send with stereo return via an insert (to maintain correct delay compensation). I have mono sends to an echo chamber and plate reverb and both have stereo returns. I use an aux channel now and I can use the insert with just one channel sending the program material using the stereo D/A. It's fine giving up one of the D/A to go nowhere, but then I need to watch the panning on the send of each track. It either needs to be all to one channel (L) or I need to remember not to use Follow Main Pan. If I just use the send out to a mono I/O and the aux return with the stereo I/O the delay is unbearable and ever changing between sessions. Just curious, Schwab
Mac Pro, Pro Tools HDX, Orion 32 HD (2), Pure2 ADDA, Solaris DA www.schwabmusic.com |
Re: Mono Send with Stereo Return via Insert
It seems as I have solved the puzzle. I am able to send a mono bus (in the sends) to a stereo Aux. Simply typing out a post and thinking about it has solved it. The DUC has done it again.
Schwab
Mono Insert consumes stereo I/O | acacia | Pro Tools TDM Systems (Mac) | 19 | 08-04-2010 03:39 PM |
Focusrite ISA 428 balanced insert send and return | tripstation | General Discussion | 4 | 01-02-2010 12:51 PM |
002 SEND RETURN INSERT OUTPUT INPUT PROBLEM!!!!! | Jim Casey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-19-2007 12:19 AM |
Mono to stereo send | davetron5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-28-2003 07:43 AM |
stereo/mono send question | dw | Tips & Tricks | 2 | 11-01-1999 03:11 PM |
