USB Cable
Is the USB cable supplied with the 11r, a dongle?
It seems a standard USB cable will not work. Can anyone confirm this? |
Re: USB Cable
Any usb cable should work, as long as it's the right type. What I mean is, it's a different (smaller) jack at the end that goes to the 11R vs. the end that goes to the computer (which is bigger).
But this is a standard configuration, with many aftermarket cables of this type available. It's the same type of cable used with many printers, midi keyboard controllers, etc. |
Re: USB Cable
All USB cables aren't equal. Some provide bus power, some are data only. There are other variations but yeah, a standard USB "Printer" cable should suffice.
Re: USB Cable
I wasn't aware of some of that. I was mainly pointing out the the 11R cable is nothing proprietary.
Re: USB Cable
Yup it's pretty generic and works good on my system. I've also used other cables without any issues. There's always a possibility of one of the pinouts being broken inside the connector or back shell (such as it is) of the cable that's not playing ball.
Re: USB Cable
Any generic cable should work, but we have seen some problems with some lower quality cables.
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
Re: USB Cable
What is the maximum usable length?
Re: USB Cable
from USB.org:
Q1: How long of a cable can I use to connect my device? A1: In practice, the USB specification limits the length of a cable between full speed devices to 5 meters (a little under 16 feet 5 inches). For a low speed device the limit is 3 meters (9 feet 10 inches). |
Re: USB Cable
It's about 16' max distance. I have a 15' run with an extension cable from my Oxygen 61. No problem with it. You can go longer if you get something like this:
IOGEAR 36ft. Booster It's kind of like putting a buffer in a very long cable chain. You know how in a long say 25' run from the guitar to the pedal board then another 25' from the pedal board to the amp? And you know about how "true bypass is necessary" internet legend? Well Pete Cornish says you lose signal strength from capacitance and need a quality buffer usually as the last pedal on the board so you don't lose the high end. Same principle.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
WTT: flex cable for short digilink cable | tripstation | Buy & Sell | 1 | 08-21-2012 01:22 AM |
switching from USB cable to Firewire cable | moonwalker2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-02-2009 08:21 AM |
Is cable for 24|Mix -> 882/20 standard SCSI-2 cable? | Last Legend | Pro Tools TDM Systems (Mac) | 2 | 01-18-2003 12:36 AM |
Digi 001 I/O Cable Question (need longer cable) | M@tt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-16-2001 01:47 PM |
Digi 001 I/O Cable Question (need longer cable) | M@tt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-15-2001 10:08 PM |
