Old 05-02-2009, 11:59 PM
scottthafoo scottthafoo is offline
Talking DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available.
I'm trying to record audio from my Roland Fantom XR sound module into FL8 using midi & audio with my M-Box 2. Every time I select Digi Asio Driver in the FL8 mixer it brings up a prompt that says
"Error While Creating ASIO Driver"
then another prompt says
"Not Enough ASIO output channels available. At least 2 Channels are needed"
What could be creating this conflict?
Any help other than reinstall both would help! I've reinstalled askes Image-Line and FL8 forums. Nobody knows. You guys never let me down!
Old 05-19-2009, 03:03 PM
jstar jstar is offline
Default Re: DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available.
it says the same thing for me im just trying to record with my condenser mic but yet that same thing comes up nd its been like that for months now...sighs...
Old 05-19-2009, 05:35 PM
DigiTechSupt's Avatar
Do you possibly have Digi hardware selected in the Sounds and Audio Devices panel? That may prevent the ASIO driver from loading - if the MME driver has control of the hardware, other applications won't be able to use it.
Avid Audio Tech Support
Support FAQ
Old 08-28-2009, 08:37 PM
md2802 md2802 is offline
Scottthafoo,
I had the same problem for ages... if you go to where you installed Pro Tools and there should be a folder there called "Drivers" (C:\Program Files\Digidesign\Drivers) there should be a file there called "DigiDriver". run it and click "install". when it finnished i was able to use my mbox with fl8 again.
hope it helps
Old 09-17-2009, 07:04 AM
niconene niconene is offline
Thank you for that answer, you´ve fixed my humor towards this M-Box. Now I can not only use it with FL 8, but also with reason, Audition, and so on.
Thanks again
Old 03-11-2010, 07:40 PM
eliyahu eliyahu is offline
Default DIGI ASIO DRIVER PROBLEM WITH FL 9 "Not Enough ASIO output channels available.
Hey..
I am running FL 9 on Mac OSX with Parallels and want to use the MBox 2 as a driver. When I open up Audio options in FL9, The Digidesign Driver is present but I keep getting this message "Not Enough ASIO output channels available. At Least 2 Channels are needed." Then it appears to be disabled. How Can I change this so that I can use the MBox as a Driver? Anyone?
Old 03-11-2010, 07:57 PM
Shan's Avatar
Shan Shan is offline
Default Re: DIGI ASIO DRIVER PROBLEM WITH FL 9 "Not Enough ASIO output channels available.
Originally Posted by eliyahu View Post
Hey..
ASIO in OSX? Don't you mean CoreAudio?
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 03-11-2010, 09:10 PM
No. It says ASIO. When I open FL 9 and go to option Audio settings, it says the Digidesign Driver is present but it is disabled..
Old 03-11-2010, 09:15 PM
Shan's Avatar
I just re-read your post and noticed you are running it in a VM so I'm not sure if this will even work. What you want to look for in FL is the DigiASIO driver, not the regular ASIO driver.
Shane
Old 03-11-2010, 09:29 PM
I have The ASIO Digidesign Driver selected and it appears to be disabled. If you have any recommendations it would surely help? Thanks in advance...
Not enough ASIO output channels available.at least 2 channels are needed. kudca Getting Started 1 05-26-2013 04:05 PM
003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem! Slaido 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-22-2011 06:32 AM
Error: Channels 0/0 could not be set on ASIO driver chili1222 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-03-2009 09:59 AM
digi asio driver problem after installing PT8? harmonik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-10-2009 02:36 AM
Groove Agent 2 and Digi ASIO driver - problem denka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2006 09:07 PM
