Old 09-02-2011, 06:45 PM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
Lightbulb Artist Transport: Application Lock Issues / Other suggestions
Trying a few things over here and noticed a few bugs with the Transport.
I'm working with 2 software at once, Logic and Sibelius 6. I have 2 mixes and a control locked on Logic and I'm trying to keep the Transport unlocked so that I can use it in Sibelius.
I remember posting a thread a while back about the RTZ button on the mix not staying locked on Logic when it should. Well now I have found another lock-unlocked issue:
It seems that the Jog wheel (and also job wheel softkeys commands) refuse to work when some other units (mixes or control) are locked on Logic. I had created 5 softkey commands to navigate in Sibelius with the jog Wheel, and they only work when Logic is closed, even if the Transport is not locked on Logic.
Other than that, the Transport screen still says "Logic Pro" even if the unit is not locked on Logic at all. The lights on the units change accordingly, but not the name of the application in focus. Perhaps this is done because other units are locked on Logic?
Other suggestions:
Would it be possible to implement graphical meters on the control screen? Or would this take too much Ethernet bandwidth? It would be nice to have different types of graphical feedback for the playback and there is more than enough pixels on the screen to display at least 32 tracks.
The same goes with the control room volume, there is no graphical feedback.
Finally, why not develop EuCon specific plugins?
You could have those plugin work in correlation with your firmware and Eucon updates, and make use of the touch screen in a way no other plugin can. People that like the plugin would be interested in the hardware, and those fortunate enough to already have the hardware would continue to support financially your enterprise by buying those plugins. Just from a business perspective it's a good idea. I can imagine many ways to use that screen, for example oscilloscopes and spectral graphs.
Anyway, if I wasn't finishing my PhD atm I would probably propose my services to help direct such a project from an artist's perspective.
Thanks for reading,
Old 09-05-2011, 09:36 AM
Default Re: Artist Transport: Application Lock Issues / Other suggestions
Also see this thread about the Jog Wheel:
http://duc.avid.com/showthread.php?t=307061
Old 09-13-2011, 10:05 AM
DDDaniel DDDaniel is offline
not replying to the 'other suggestions' but to the Appl. Lock issues.
Since I upgraded to 2.6.1 I can not lock my Transport to PT9.05 anymore. Both the checkboxes (entire surface/transport) do not want to get checked.
Trashed the Euphonix prefs in the library, but that does not help.
Any idea's?
Tx
Dan
Old 03-02-2013, 09:04 AM
Default Artist Transport: Application Lock Issues / Other suggestions
Just upgraded to 2.7, unfortunately lock to application still does not work....
Old 12-04-2014, 10:08 AM
inqwizitor inqwizitor is offline
using eucontrol 3.1.3 and i'm unable to lock the artist transport to an app of preference (itunes). Possibly you can only lock to EuCon supported apps??? haven't tried locking it to PT yet...
inqwizitor
Avid Artist Transport Issues siwellewis Artist Series 1 01-07-2014 02:35 AM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
ARTIST TRANSPORT: Transport knobs do not light up when pushed smallchamber Artist Series 0 02-26-2013 05:36 AM
Artist Transport HUI Issues Keith Sylvester 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-26-2012 07:01 AM
Using Artist Control with Artist Transport? GrievousAngel Windows 2 03-14-2012 03:29 PM
