Old 02-22-2003, 12:45 AM
LarryLatham LarryLatham is offline
Default Best Way to Master
Just curious to see what everyone's work flow is when mastering a project.....
For example: which do you think is better?
A: Denoise (clean up) first then EQ and sweeten or
B: EQ and sweeten then Denoise (clean up)
Also....Would you do them all in a chain (in one bounce) or in two seperate bounces?
Very interested to hear what you guys have to say!
Old 02-22-2003, 09:41 AM
Wolfgang Eller Wolfgang Eller is offline
Default Re: Best Way to Master
First of all: You are on the best way to do a real pro mastering.
First reason: It seems you never did it before.
Second reason: You have no idea what to do.
Third and most importand reason: You have to master your own mix by yourselve.
For the plugin chain: Take all the plugins you have in a chain (therefore you have to use a lot of aux channels)and crank every single plugin till it´s output is RED (that´s the focusrite sound)then the sound is perfect.
Cheers Wolfgang
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 02-22-2003, 01:26 PM
Mark Haliday Mark Haliday is offline
You may have noticed the lack of clever response to your post There are a number of reasons for this one of them beeing that this part of the duc is mainly dedicated to troubleshooting some very sticky Mac vs PT issues, not really ideal to post general questions.
As for denoising, this is not a common process in mastering unless you are in the business of restoration or simply giving a new lease of life to these old hissy cassette demos...
Old 02-22-2003, 02:14 PM
<font size="2" face="Verdana, Arial">And these topic's are....Oh and this is just from the FIRST PAGE...if you don't have an answer (which you obviously don't) just ignore this.....
Firewire Drives...Fans or No Fans?
MIDI I/O's not working with 6.0/OSX
logic & sync IO
A Midi question for a Guru
My 8.6 "faints" every time I play a CD ...
Any way to randomize without 1st normalizing??
List great analog summing mixers for PT's(16 to 32 channels only)
Firewire drives larger than 120GB
Logic 6 forum
HD Reverb
OSX Plugin info goes here--->
Penta
Akai sample cds
Logic6 is out
G4 quieter fan exchange
Powr Dither and noise shaping settings, what do they do?
Midi Patch names in OSX (.midnam)
This is one for the book
Apple MDD noise fix offer
Old 02-22-2003, 03:20 PM
AE AE is offline
<font size="2" face="Verdana, Arial">You must make amazingly clean recordings. Every record I've ever mastered required denoising; there always seems to be a few clicks, squeaks, and other minor but distracting glitches that are nice to omit.
Old 02-22-2003, 04:10 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
The right answer is to do whatever sounds best. No two projects are ever the same.
The key to mastering is a great monitor environment so that you can compensate for the shortcomings of the monitor chain that was used for mixing or tell when no compensation is needed.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 02-22-2003, 06:34 PM
PlugInJunky PlugInJunky is offline
I would have to say....for a begining approach...try Denoising if its necessary....Most of the time...a lil noise can add to some natural sound
but try:
the C4 plugin and the L2....if anything you can put a parametric EQ post C4 if necessay...but the C4 is great.....
but for beginner the T-Racks is a great buy...try that out.... try that out...if you can get your hands on TC electronics Finalizer..that could be of some help..Not the Plugin the real thing..lol....its a great box if you tweak it right....
DJ Jorge Felix
[email protected]
Midi Programmer/Remixer
I make beats - Love that line
Old 02-22-2003, 07:12 PM
Great thanks to the last three or four guys who have posted....really good info!
I guess I probably should have said something other than mastering though and maybe that would have helped.
Basically, like someone above said, everything I get in here needs some denoising or TLC. I just wondered which other guys do first (denoise/sweeten or sweeten/denoise) and if anyone has a hard and fast rule that they like to use.
Thanks again!
PS....speakng on denoising what does everyone like best? Cedar for PT, noNoise, or Audio Cube (not for PT though)
Old 02-22-2003, 07:13 PM
Joe Egan Joe Egan is offline
Lessons I learned from mastering engineers:
Don't bother trying to play the piano unless you have a Steinway, years of experience and great ears.
Don't bother trying to write a song unless you have a quill pen, years of experience and great ears.
Don't try to learn how to do audio mastering unless you have years of experience and great ears.
Only mastering engineers have great ears, you're not a mastering engineer, so therefore you must not have great ears. So don't bother trying.
just jokin'
Old 02-23-2003, 12:44 AM
Cheers Wolfgang
<font size="2" face="Verdana, Arial">What a very insightfull "witty" post....so does someone with a brain have an opinion?
Thanks!
Production Master Or Original Master Zelos General Discussion 3 02-14-2011 07:52 PM
Fixing Clipping in Master in Master Fader pakobo7 Pro Tools M-Powered (Win) 10 09-16-2006 10:53 AM
TC Master X or Waves Master Bundle TiPo Pro Tools TDM Systems (Mac) 4 02-15-2003 11:41 PM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
Master Fade & Master Plug Ins Kenny Gioia Tips & Tricks 10 04-17-2001 02:39 PM
