Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 12-08-2016, 01:37 PM
Acustiman Acustiman is offline
Default TD-20 cross stick/snare velocity
Hi all,
Hoping to glean a answer from anyone using the Td-20 as a trigger, in this case to Slate drums...problem is I've got a cross-stick intro-and throughout the song mixed with a snare hit and the stick is too LOUD!...is there a way to lower the velocity of JUST the cross-stick all AT ONCE...& not the snare?...Ive tried everything...
-thx
Old 12-08-2016, 07:40 PM
albee1952 albee1952 is online now
Default Re: TD-20 cross stick/snare velocity
Assuming the cross-stick shows as its own midi note value, open the Velocity lane. Click on the tiny keyboard(left side of the midi/instrument track) on the note that triggers the cross-stick. Doing that will highlight the velocity value(the tiny diamonds) for all the cross-stick hits. Drag any one of the little diamonds down and all will follow.
Alternately, open the Slate plugin mix window and adjust the cross-stick volume
Old 12-09-2016, 09:26 AM
Albee thanks man! Problem is SSD4 doesn't include a cross stick channel, and if your compressing snare with verb etc. the cross stick gets the same treatment!
I got the velocity lower (thanks) Are you still using the TD's and have the same problem?
-thx
Old 12-09-2016, 09:58 AM
I haven't used E-drums in a while. What about lowering the sensitivity on the rim trigger? One option you might not have considered; use a real snare drum I got great results going hybrid with real snare, hat and sometimes all real cymbals(the overhead mics just added some "air" to the overall kit sound). You could also put up a mic and get one of those cross-stick blocks
One other option, if you print drums to audio(which I always did), I would add a blank audio track below the snare track, separate the cross-stick audio and drag it to its own track. That also allows for different EQ and reverb
Old 12-09-2016, 10:30 AM
Great, yeah I'll work on the trigger first...living arrangements prohibits live drums, but the cross stick block could work! Thanks !
Old 12-13-2016, 09:27 AM
Emcha_audio's Avatar
-thx
This is typical in most software as it represent REAL life action. Unless you're a madman ( I was once) and went through the whole take to manually mute (on a analogue desk to the studer 2 inch track) the send to a reverb so that the cross stick wouldn't get that treatment, then automatically it would get the treatment because it's the same mic that actually pics up the snare, rimshot and cross sticks.
Manny.
Wave-T.com
Old 12-14-2016, 08:12 AM
FWIW, I usually replace the cross stick sound. I bus and record the drums sounds as audio and then move the cross stick hits to a separate track and use Drumagog to play my own samples
Can't edit velocity only anymore? Notes copying with velocity data... kingtinker Pro Tools 10 5 11-12-2011 10:53 AM
chasing the snare with a new snare sound toolgirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 11:00 AM
stick against stick in strike harryk Virtual Instruments 0 09-06-2008 12:06 PM
How to get the kick and snare velocity even? Tormentor MIDI 4 10-30-2004 05:07 PM
DTS & Stick of Joy... Arno Peeters Tips & Tricks 4 10-13-2000 01:08 AM
