Live-Recording with MADI to USB (ProTools11)
Hi, I'm going to do a live recording of only a few tracks with my System. I was advised by the Audio-People of the venue to install Digico-drivers for the UB MADI card and I will get a USB Signal from their interface. Also they told me to make sure I have enough space on internal HD (SSD 250 in my case).
1. Isn't it better for Pro Tools to work with an external Drive instead of the internal drive? Maybe that rule doesn't apply in that particular setup? 2. Will this work regarding compatibility? Is there a danger to get drop-outs while recording? I have no possibility to test. Is anybody experienced with this setup? Thank you! Last edited by JonasW; 01-03-2018 at 07:16 AM. |
Re: Live-Recording with MADI to USB (ProTools11)
Everything worked fine.
Did you find an easy way of passing the track labels across to Pro Tools?
Or did they just default? |
No, I had to go to I/O setup and create paths. I had to hear which was which afterwards. Maybe the FOH-guy didn't assign them although it would have been possible. It was a busy night.
When you say you had to create paths I guess you mean that you just added the correct number of Tracks and the mapping to the MADI was automatic (MADI 1 to first track, MADI 2 to second new track, etc.); That is what I use when doing live recordings from my DigiCo desk (the good news is that I can then replay through the desk over the PA if I want to review any settings; plus if an understudy wants to practice I can replay the relevant number, and block that track so that track alone is coming live)
The problem is I have not yet found a way of labelling the tracks in Pro Tools automatically from any labels I apply to the desk channels, MADI stream etc. I am investigating the import possibilities for Pro Tools in the hope that I can generate a file (CSV, XML I do not care) and then import to label the tracks. If that is possible then I can parse the Session report from the DigiCo desk and create the file. It will be a pain to create the app that will do it but would save me having to label the tracks twice- once on the desk and again in Pro Tools. As this particular MADI stream could have up to 56 tracks, this would be a big help |
madi recording with 2 stage racks | aris | VENUE Live Sound Systems | 3 | 02-08-2015 07:58 AM |
profile madi card to PT recording | pmueller | VENUE Live Sound Systems | 5 | 08-22-2014 10:49 AM |
Levels (Live Recording) Madi | vinlance | Pro Tools HDX & HD Native Systems (Mac) | 1 | 08-31-2013 03:06 PM |
Looking for madi 128 track recording solution | pmueller | VENUE Live Sound Systems | 11 | 04-04-2013 09:55 AM |
Live recording from Venue Profile possible with Digico UB Madi & PT10 CPTK? | briancares | VENUE Live Sound Systems | 2 | 09-11-2012 08:04 AM |
