Old 07-09-2004, 07:47 AM
MAM MAM is offline
Default Question for FlorianE about X-Mon
Hey FlorianE,
Can you detail the issues you are having with the X-Mon and Dolby equipment? We are considering an Control D purchase and would like to hear any feedback in regards to monitoring surround for post. Thanks in advance.
Matt
Matt Melberg
Audio Editor / Mixer
RIOT Atlanta
Old 07-10-2004, 03:27 AM
FlorianE FlorianE is offline
Default Re: Question for FlorianE about X-Mon
Matt
XMon is lacking monitoring Insert/Return points which would be needed to 'embed' the Dolby encode/decode chain within the monitor switcher.
Also, I believe setting monitoring levels at .5 dB steps is too coarse. At 7.1, stepping .5 dB on 8 discrete monitor chains can make much more than .5 dB change in SPL.
Additionally, the cable linking ICON and XMon is a RS422/MIDI/StereoAudio hybrid. Max cable length is limited by MIDI to something around 100ft. If you need more, you need to insert some sort of buffer-line driver. As XMon usually sits near ProTools, depending on the layout of your studio, it can easily happen to take more than 100ft from PT to the mixing aerea.
But XMon is not a buy/don't buy issue. We simply didn't connect it (ICON won't mind) and use our old, by now somewhat outdated (because analog only) Magtrax12 switcher. It gets the HD192 Output and takes care of the rest. Obviously, we are looking around for an alternative switcher or a mod to XMON.
-Florian
Old 07-12-2004, 07:35 AM
MAM MAM is offline
Yikes, .5 db! I think that's pretty coarse as well. I hope they can address that. Thanks for the info.
Matt
Matt Melberg
RIOT Atlanta
Old 07-17-2004, 05:10 PM
Hostage Hostage is offline
Hello, Has anyone looked into Harisons Digital Super Mon System I know it is expensive just what we need spend more money. Too Bad Otari never moved foward on Pic Mix to make it digital anouther oustanding audio company that did not see the future
Old 07-29-2004, 10:30 PM
Samhein Samhein is offline
Hi Florian,
We're new to this Dolby encoding/decoding thing, so I hope u can bear with me. I thought that simply sending out the 8 channels of audio via the Alt Outputs of XMon to the Dolby encoder would be sufficient? The decoder's output will then be connected to XMon's Surround Input for us to hear on the speakers.
Won't that work?
Old 08-03-2004, 02:29 AM
Sorry to answer so late. Holidays.
Should work, of course.
But is not flexible.
As far as I can see, you'd have to repatch for different working modes.
Like A/B monitoring when you record stems.
Or quick-checking for LCRS-compatibility.
And what about the different monitoring levels?
Or using any other than ICON's meters?
Florian
fruity loops in pro tools question...not regular rewire question nutrinoland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-23-2010 12:39 PM
quick question - Mbox Mini question - i forget JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-18-2009 02:55 PM
Another optical expansion question question for boffins Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-23-2008 11:21 PM
General Venue Automation Question - (Maybe dumb question) TwoPort VENUE Live Sound Systems 5 12-21-2007 02:41 PM
Chipset Question/Hard Drive Question andrewkstone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-26-2006 08:15 AM
