Old 05-03-2018, 08:24 PM
driver8matt driver8matt is offline
Default Lost drivers for Mbox 1
Hello all. I bought an Mbox 1 in 2006. I had a house fire destroy my computer but the Mbox survived. I don't have any of the drivers to load it on to my new computer. How or where do I find them? I sent Avid an email, but haven't heard anything.
Old 05-03-2018, 09:53 PM
Top Jimmy's Avatar
Default Re: Lost drivers for Mbox 1
Have you been to this page?
https://archive.digidesign.com/download/mbox/
Or this one?
https://archive.digidesign.com/downl...diodrivers/xp/
James Cadwallader
Old 05-04-2018, 10:05 AM
The Weed's Avatar
The Weed The Weed is offline
IIRC, the drivers are part of Pro Tools LE and the original Mbox 1 is only good to PT LE 8.0.1, which is way old. Windows XP in my case.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-04-2018, 03:38 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
The older the Mbox the older the drivers you have to use. I have an old mobile pre that works fine with 18.4 and win7 but only with the oe driver. So no matter what you try , remember if It doesn't work you can go with an older driver also.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 05-04-2018, 04:59 PM
The Weed's Avatar
The "drivers" to use Pro Tools LE with the Mbox are part of the PT LE install. As Top Jimmy posted above, the ASIO and Wavedriver installs allow third party programs to use the Mbox. The link only refers to PT LE 7. I'm not sure any driver he can find will work with any Windows OS past XP. That said, Windows 10 does have compatibility settings which may allow them to work, but that's debatable. Almost 100% sure Pro Tools isn't going to work. What would be an interesting experiment would be to load the ASIO driver - if it will indeed install - and then try to get a current version of Pro Tools to use the Mbox through the ASIO driver. Then again, there are a lot of inexpensive interfaces out today that are (way) better than the original Mbox.
SonoBus
Old 05-04-2018, 05:22 PM
64GTOBOY's Avatar
I did not know that, my MobilePre came with a Driver installation disc and a PT 8 LE disc separately. I couldn't find the disc when I was setting up my second laptop and just downloaded a copy from AVID that worked fine(as I said , the oldest version). That was Win7 and PT 12.1 Native
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available Avid Technical Alerts 0 10-30-2012 04:24 PM
MBox Pro 3 NEW DRIVERS! jryser macOS 0 06-29-2012 07:33 PM
MBOX Drivers aschatzb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-09-2007 07:37 AM
Mbox/ 002 drivers? Brew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-01-2006 09:11 AM
