Old 08-08-2019, 03:34 PM
Armando Armando is offline
Default Bypassing Aux channel increases overall mix volume when bypassed
Hello! Not sure why this is happening. I’ve got a guitar track on it’s own channel. Then from that mono channel I’m bussing signal to a stereo Aux channel with a reverb on it. The buss level is set to “unity”. The reverb is panned 100% L & R and it’s level is set around 1/3rd of the way up.
Now for whatever reason, if I “bypass” the reverb plugin on it’s own Aux channel I lose the reverb completely but the guitar level goes up in level.
Why is this happening? Am I missing something here?
Thanks in advance!!
Armando
Old 08-08-2019, 04:27 PM
BScout BScout is offline
Default Re: Bypassing Aux channel increases overall mix volume when bypassed
You are missing how reverb plugins work.
When you bypass the reverb plugin you are just sending double the dry signal out since it is no longer being processed.
Which obviously will be louder.
If the reverb plugin is on its own aux, do the common sense thing and just mute the aux out.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-08-2019, 04:37 PM
Thanks! Having a brain fart! Actually I thought it also happened when muting the track but I probably over looked that. Thanks again!
Armando
003 is bypassing monitor knob at full volume on one channel only ductape22 FireWire and USB Audio Interfaces (Mac) 2 01-09-2015 07:42 AM
Sample rate conversion & consolidate increases volume?? D'Animation Post - Surround - Video 1 02-28-2012 07:39 AM
Channel volume problem getinnocuous 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-05-2010 02:32 PM
Lovering volume on track channel? Sevdah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-18-2009 12:02 AM
Can I Group a Channel Volume with an Aux Send Volume? acacia Pro Tools TDM Systems (Mac) 10 08-10-2007 12:26 PM
