Old 02-20-2010, 11:41 AM
Nesp Nesp is offline
Default Virtual midi keyboard for pro tools
Is there a virtual midi keyboard compatible with pro tools?I know bome' s mouse keyboard but i don't know if it works with pro tools...!
Old 02-20-2010, 11:42 AM
Dism Dism is offline
Default Re: Virtual midi keyboard for pro tools
http://vmpk.sourceforge.net/
works for both Mac and Windows. Never used the Windows version, but it works flawlessly on my Macbook.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 02-20-2010, 11:48 AM
that's cool i found chirp too..from tanagersoftware..!it doesn't look good!
Old 02-20-2010, 12:29 PM
Never tried Chirp personally. Might give the demo a shot... but vmpk is free and works quite well for me.
D
Old 02-20-2010, 01:01 PM
well i have problems getting vmpk to work with pro tools can you help me?is there any manual for windows?
Old 02-20-2010, 01:08 PM
Chirp and here is how Running Chirp with Pro Tools.
filosofem
What seems to be the problem?
You should be able to route it to an input midi channel in pro tools. Is it showing up in input devices?
D
Old 02-20-2010, 01:25 PM
i installed midi yoke..and vmpk..and then..i went into pro tools..made a new session..made an instrument track..with some plugin (superior drummer)...and then opened vmpk..i set the input of vmpk..to midi yoki 1 and the midioutpu to yoki 1 too!...i press keys and i can see only in the vmpk something moovin'...but not in pro tools...do i need to make some setting in pro tools?
Old 02-20-2010, 01:29 PM
basically i can't even hear notes when i draw them in the piano roll...why is that?..then i play drums just to hear them inside the plugin i hear the kick snare etc...but when i draw all over the piano roll with the mouse i get nothing when i play it..
Old 12-19-2011, 05:21 PM
sforzando sforzando is offline
Outdated, I know. I encountered this problem as well. PT 10 automatically recognized vmpk as an output automatically but does not automatically enable it as an input.
Enable vmpk as a MIDI input device in Pro Tools:
Setup>MIDI>Input Devices Check the box next to "vmpk Output."
The easiest way to record MIDI from vmpk:
Create an Instrument track with the desired plug-in I/O = Bus 1 / (your preferred output)
Now make a MIDI track I/O = vmpk Output / (The name of the instrument plug-in)
**Record-enable the Instrument track, not the MIDI track
Hope this helps.
Using Virtual Instruments without Midi Keyboard hendrixrocker2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-24-2024 02:09 PM
Virtual Midi Keyboard on Pro Tools SE vinicius.almeida123 Pro Tools SE and Essential (Win) 5 07-01-2012 07:21 PM
Virtual MIDI driver / keyboard mapper for PT9 on laptop MotifMan Pro Tools 9 2 06-21-2012 11:40 AM
How to control Virtual Instruments via external Midi-Keyboard? Sonic-B Virtual Instruments 5 05-23-2011 02:36 AM
virtual MIDI keyboard for Intel on PT ? Simon666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-19-2007 06:06 AM
