Old 05-02-2018, 11:22 PM
jimmivalentino jimmivalentino is offline
Default Old 'Elastic Audio.aaxplugin fatal error' on new Win10 computer
So this next install will be my 5th re-install of Pro Tools in about a month - basically since I was shipped my new PC.
I got it briefly stable on my 3rd install, after doing some voodoo with the ElasticAudio.aaxplugin (based on the old guides to fixing the issue with iZotope Radius library within it), but managed to corrupt ProTools.dll while I was sniffing around the Avid Program Files folder while looking for a Euphonix thing I was trying to debug. So there goes that.
Re-installed and I'm having the exact same issues as previously with both 2018.4 and 2018.3. They seem to all stem from the iZotope Radius library used within Elastic Audio, which FL Studio also uses (these are my two primary DAWs, there is no possibility for isolation).
Currently, I'm getting AAE -9060 errors every time I hit play the first time in a project, yet Pro Tools is running on a SATA SSD which is virtually empty, the project files are run off an NVMe, and this is not in a single project but any project including blank ones so probably not a audio file/fade corruption. I also have issues with the playback engine and hardware dialog boxes freezing then crashing Pro Tools or just not loading at all. This is in addition to the 'Fatal Error' message that happens when Pro Tools starts up and can't load Elastic Audio. There is probably a few more less occurring error messages, but these are the main ones - and from what I've read, they all point to the Radius library.
How can I fix this?
2013 Retina MBP - MacOS Sierra 10.12.5
SFF i7-8700 with Samsung NVMe - Windows 10
Pro Tools 2018.1
Old 05-02-2018, 11:33 PM
Default Re: Old 'Elastic Audio.aaxplugin fatal error' on new Win10 computer
Detailed Specs (if useful):
OS: Windows 10 Home Version 1709, 64-bit
CPU: Intel i7-8700
RAM: Vengeance LPX 16GB 3000MHz
Motherboard: ASRock Fatal1ty Z370 ITX
OS Drive: Samsung 860 Evo 1TB SATA SSD
Projects Drive: Samsung 960 Pro 512GB NVMe M.2 SSD
Graphics: Integrated, Intel HD630
Pro Tools 2018.1
Old 05-03-2018, 02:35 PM
Have you re downloaded the installer? or keep using the same one?? I would re download it.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 05-05-2018, 10:29 PM
Have downloaded the installer twice and also tried 2018.4 (which was the first one I tried). No luck.
Pro Tools 2018.1
Unsupported Audio Buffer Size Error ProTools 11 Win10 thegrinch Pro Tools 11 2 09-17-2017 09:26 AM
PTF 12.3.1 Windows 10 Elastic Audio.aaxplugin could not be loaded ktweedy1 Pro Tools | Intro Discussion 3 06-27-2017 11:43 AM
Win10 64bit Computer Specs harryk Pro Tools 12 6 02-04-2017 02:29 PM
Elastic Audio Error Kenny Gioia Pro Tools TDM Systems (Mac) 18 07-09-2010 06:19 AM
Fatal error message with Elastic Audio timtimtim Pro Tools TDM Systems (Mac) 4 05-20-2009 10:02 AM
