Routing Falcon instruments to Pro Tools
Ok so I have Falcon up and running, enabled the soundbank and loaded a clav. It sounds great.
In the Audio & Midi Setup I can select the audio output. Available options are the mac speaker, straight to my audio interface (Metric Halo ULN8) or: Pro Tools Aggregate. I guess I have to select the latter so I did. Then in PT I created a track, I had an instrument track but I suspect that was wrong. What kind of track should I create in PT to receive the Falcon signal? Guess that is the first step. Note: On my UVI page under Getting Started it sais dl the manual but clicking on that link doesn't lead me to really dl; it only opens the manual (which is very limited) in another tab in Safari. So I'm affaid I will have to keep pulling your sleeves for a while. I will check the tutorials tomorrow but I really have to install another computer for conveniently viewing them. And the machine is messed up drastically. I want to put Linux Ubuntu on that one to have an additional computer else it sucks. So this will be my last question for a while I hope. I can find out some things by myself but here I am really stuck. |
Re: Routing Falcon instruments to Pro Tools
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Thanks Lesbrunn. I'll try that tomorrow (1:30 am now). The tutorials make me drewl.
Got it. The trick is to not run Falcon simulteous with Pro Tools, like good old Rebirth and Reason (thatś where I went wrong). Instead you can just select Falcon in the instruments section in the insert-list in the mix window. as a plugin.
Each instance of Falcon (on each different PT instrument track) should have its part set on Master output. To my findings so far there's no using other Falcon outputs in this setup. Additional outputs apart from the Master fader are only to be used when Falcon runs standalone. |
If you have one Falcon instrument track, you can have several MIDI, audio and aux tracks to set up several instruments in that one instance. Falcon has 16 additional stereo buses back to PT that you access for audio or aux tracks in the input selector for the track - it's under the Plug-in catagory. To send multiple MIDI channels you just create MIDI tracks output set to the instance of Falcon with separate channels in the MIDI track output selector. No need to have multiple instrument tracks with the additional overhead.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
thx john
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. |
Some help here: https://www.groove3.com/uvi-training...lcon-Explained
Eli uses Logic, but all the examples can be applied in PT. I/O is I/O. The G3 tutorials are well worth while and they happen to be having a sale. For $90 unlimited access to all videos for a year. Also plenty of stuff available on YouTube and the UVI site.
Falcon sound bank installation question | Voideco | Pro Tools 12 | 24 | 06-27-2017 02:55 PM |
Falcon - New VI from UVI | DonaldM | Virtual Instruments | 3 | 11-09-2015 06:45 AM |
Native Instruments Pro 53 and routing to bus = crash! | crizdee | Pro Tools TDM Systems (Mac) | 5 | 08-17-2009 03:08 PM |
Routing vst instruments into audio track in pro tools 8 | ostrange | MIDI | 1 | 05-19-2009 05:24 PM |
Routing click track to Quicktime Musical Instruments? | SWW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-18-2003 04:44 PM |
